Inexpensive Weather Proofing for Electrical Outlets Insulation, Window Insulation, and Fixing Door Drafts That Will Save You Big Bucks
Intro: Inexpensive Weather Proofing for Electrical Outlets Insulation, Window Insulation, and Fixing Door Drafts That Will Save You Big Bucks
I month ago on cold, wet and windy night I bent down to plug in a light and felt a breeze of cold air coming form the electrical outlet. I was kind of alarmed, we have heat to warm the house but is it doing any good if cold air is still getting into the house? I was also puzzled because I thought that exterior of the house would shield the house against wind.
I finally decided to do something about it when our next winter power bill came.
STEP 1: Electrical Outlet Insulation Materials
STEP 2: Window Insulation Materials
STEP 3: Door Draft Materials
If you have space and baseboard heaters, warm air can easily escape from the bottom of your door. With this simple project you can seal in the heat and keep the cold out. This also works great as a noise insulator.
I picked up this backer rod at a local store call Hardware Sales. It comes in various diameters up to 1. If you have a larger gap under your door, you could probably buy pipe insulation foam. Under materials there is a simple calculation to finger out how much material and backer rod you will need to complete this project.
Materials that you will need to complete this project:
+ 5' x 1dia. Backer Rod ( door widths x 2 x #number of doors = _Ft)
+ 11" x 33" Slippery Fabric ( circumference of foam tube + _ door width x 2) + 1" seam allowance = x # of doors = )
+ Thread to match fabric
Useful Tools:
+ Sewing machine (you could probably hand sew it if you wanted to)
+ Needles to pin material
+ Ruler and Tape measure to measure and cut fabric
+ Scissors
+ Chalk pencil to mark fabric without leaving permanent marks
Useful Tools:
+ Scissors
STEP 4: Door Draft Construction
My door is 30" wide, about 1.5" deep, and I'm using 1"dia. backer rod. After doing the calculation I figured that I needed a piece of material 11" x 33". The three extra inches will give me a 1.5" seam allowance on each side of the backer rod.
8 Comments
budget_audiophile 10 years ago
Great ideas. Quick note however, pink Fiberglass insulation is not recommended to be used directly beside electrical outlets, it is actually flammable and a fire hazard. You can use Roxul or other brand Mineral Rock insulation which is flame-retardant.
joyalove 14 years ago
MsJan 11 years ago
PLANTJOE 15 years ago
I also cut squares of foam to squeeze into the frames around individual panes of glass in windows.
The styrofoam dosen't have to be very thick. If it won't stay in by compression, You can put a 1 in. piece of 2-sided tape in the dead-center.
SLIDING-DOOR
shawnlogan 15 years ago
Pasketti 15 years ago
mistressdominastar 15 years ago
dosadi 15 years ago
