Inexpensive Solar 18650 Battery Charger
Intro: Inexpensive Solar 18650 Battery Charger
Having recently completed my 20w solar charge controller well almost, I still have to finalize the power output. As it stands I'm able to charge such items as battery banks & cellphones via 5v usb. To charge 3.7v 18650 batteries the voltage has to be reduced from 5v. A simple matter with TP4056 lithium battery charge module.
3.7v 18650 rechargeable batteries can be purchased through a variety of distributors or salvaged from discarded laptop batteries. When the battery in a laptop can no longer keep the laptop charged properly, the fault usually lies in only one or two of the group of 18650's found bundled together to supply the needed voltage. Instead of discarding these very useful batteries they can be salvaged & used in e.g. flashlights (either diy or bought off the net), arduino or other electronic projects.
This instructable explains a simple & inexpensive way of solar charging 3.7v 18650 batteries.
Read On.....
STEP 1: Parts List
In the picture above I'veincluded on the right a prior version of this project. In this earlier version I mounted the solar charge module & the battery holder onto a thick piece of plastic. This time we'll omit the plastic piece & glue the solar charge module directly to the back of the battery holder
PARTS:
3.7v 18650 battery holder with 6" leads from ebay roughly 50 cents to a buck - I would pay more for a more "robust" battery holder if I could find one. These are very flimsy but do the job.
TP4056 mini USB Lithium Battery Charging Board 1A 5v again about a dollar, less if you buy more than one
usb to mini or micro usb cable depending on which TP4056 charge board purchased
TOOLS:
Hot glue gun to attach TP4056 charge board to back of battery holder & keep wires in place
Soldering iron
A word about buying from the Chinese market vs buying local. Fantastic bargains can be had when purchasing from the Chinese marketplace. How they can deliver to my door for the cost of not much more than the price of the postage in some cases mouth-watering electronic goodies is beyond my comprehension! Being new to electronics I do make many dumb mistakes, converting brand new parts into smoldering piles of useless stench! Point being even those of us on limited incomes can afford a mistake here & there when the parts are cheap to purchase.
The reasons we must buy local are many. Sure when comparing prices local can be a bit pricier. But with that bit of markup come benefits. Better packaging, faster delivery, understandable specs & instructions, better quality along with product guarantees, & what about the jobs of the people involved in manufacture & sales?
I've barely touched on this topic as it's much too large an issue to get into here. Something to keep in mind when buying parts.
STEP 2: Solder Then Glue
There is very minimal soldering in this project. The positive & negative wires from the battery holder need to be soldered to the TP4056 after trimming off a couple inches from the ends of the wires. Once soldered hot glue the TP4056 module to the battery holder. Then add more hot glue to better adhere the module to the battery holder & to keep the wires firmly in place.
Please work safely being mindful of hot surfaces. Especially true for the hot glue as it can look cool to the touch when in fact it can cause a serious burn to one's probing fingertips!
STEP 3: Done
Allow the glue time to harden. Doesn't take long. Attach the mini usb cable & slip in a battery that's in need of charging. While this project is all about solar charging 3.7 volt 18650 li-ion rechargeable batteries, the usb cable can be inserted anywhere 5 volts (& 500mA to 1 amp) are available - be it laptop, pc, power bar, battery bank, etc.
Thanks all for taking the time to read my instructable. Please inform me of any errors should you find any &/or any improvements you come up with. Happy Tinkering!
STEP 4: Solar Charging
That's it. Since they're cheap to make it wouldn't hurt to make a couple or three.
I've entered my instructable in the MAKE ENERGY: A US-MEXICO INNOVATION CHALLENGE. A vote for my project would really be appreciated! Cast your vote at the top of this page if you please! Thanks!
STEP 5: UPDATE:
Couple items
Found same board but with circuit protection on ebay for about 50 cents US apiece but you need to buy 5,
http://www.ebay.ca/itm/5PCS-Micro-USB-5V-1A-18650-... I'd say that's a great deal!
If any of you like this project but don't have the time or inclination to put this together I've found on ebay someone has put together a version of this project & are selling it here for under 5bucks US.
http://www.ebay.ca/itm/5V-Mini-USB-Lithium-Battery...
Since posting this instructable I've found others also posted li-ion battery chargers using tp4056 here & there on the internet. Proving it's a simple, functional design worth repeating! Truth be told, they were posted before mine! lol
20 Comments
MichelF20 6 years ago
I made it on my own. But I have discovered some limitations.
I have used a 7V 5W panel.
On bright sunny days that panel delivers 4,8V by 800mA and charges perfectly the cell in a couple of hours. However once the cell is charged, the charger becomes up to 8,5V at the input, which is far over the specs of the charger IC. It than overcharges the cell by up to 4,5V, which is absolutely dangerous!
So please use at least the charger modules with built-in cell protection.
On the other side, on rainy days -and we have much of them here- the panel delivers only 40-50mA by 4,2V which is too less to power up my attached device.
For that reason I don't want to waste voltage and power by adding a voltage converter in front of the cell charger, the 40mA delivered by the cell will be just enough to run the converter! :-(
For the time being the best solution I've found is to load the solar panel with a 12V fan once the cells are charged, that drops the voltage down to 6,5V which is just fine. This happens only on hot sunny days, so the fan is useful anyway.
The Arduino data logger monitors the cell voltage and triggers the fan as soon as that voltage exceeeds 6,5V.
nikian.aghababaie 7 years ago
I'd like to charge 3x 3.7v 9800mAh 18650's in series from a 5w solar panel. Can the TP4056 charge them?
Thanks
petebarchetta 7 years ago
netbuddy 7 years ago
Your local guy will be buying from the same places as the Chinese seller, only his buying power is made by buying in bulk or if Chinese, via an old family friend or school friends or wherever he has people he knows in factories that make this stuff.
So if you don't know what you are doing, buy local, get advice and be assured.
If you know what you are doing, know what to buy and can wait up to a month then save yourself a load of $$$'s and buy international.
18650 battery 8 years ago
I would love to see the charge curve as I'm worried perhaps the charge current drip is not steady. I have noticed from some power sources and it will mess up the cell over time.
terrible tinkerer 8 years ago
Thanks for your interest 18650. Looking back at my instructable I see I haven't said much about the tp4506. Online I found at the Candlepower forums a member has created a number of graphs where you can hopefully find the charge curve.
http://www.candlepowerforums.com/vb/showthread.php...
TT
Dr.Bill 8 years ago
If you buy an AH-55 DC to DC Converter on Amazon it will charge a Li-ion battery as big as yours @ 300 mA for hours and hours. I put the AH-55 into the wood box in the left of the cart. There are several of them that I use to charge all my Li-ion batteries. Never had a problem with it and they don't get hot like in commercial chargers. Works on NiCad's too and the 12 volt battery drill motor as well
u971 8 years ago
Thanks for the inspiration made 2 for charging battery to power an arduino.
Hi u971, Glad to inspire, 2 eh? Great stuff
TT
Errol1951 8 years ago
Hi
I have been doing some research into these batteries and it is interesting how many fakes there are as you can only get about 2600 mHr's the rest are fakes you have to weigh them to find out if they are real their weight should be over 40 grams if not I'm sorry you might have a fake or you can use a watt master to measure exactly how much charge you have put in to it. Have a look around and see if you can find a reputable supplier and look on the internet to see. I have started to build some bigger units with radio and the ability to charge phones and a light as well
jmorsebrown 9 years ago
Hi. Thanks for this. What's the spec for the solar panel that I'd need for this project?
terrible tinkerer 9 years ago
Hi jmorsebrown, your welcome & thanks for your interest.
This project includes a female usb port and thus requires 5v input. I'm not an expert but in order to maintain 5 volt input it would be prudent to use a solar panel specifically rated for 5v with a usb connector attached or a panel rated higher & you attach a step-down buck converter with usb connector as in my earlier project here
petebarchetta 9 years ago
This is a very minimal circuit.You would need a different module/circuit to accomplish what you're after, beyond the scope of this ible. Sorry
Errol1951 9 years ago
there is a new circuit board similar to yours but has output terminals as well and you could hook it up to what ever you want saving taking the battery in and out its called Nice 5V Micro USB 1A Lithium Battery Charging Board Charger Module+Protection
Hi Errol1951, Thanks for your input. Where can I find a Nice 5V Micro USB 1A Lithium Battery Charging Board Charger Module+Protection? I'd like to check one out.
That's great. I'm glad you've found my instructable of use. The sun hasn't been out much the last few days but I'm still managing to get my batteries charged.
