Introduction: Inflate Your Dragon at the Gas Station
Are you turning blue when you fill up your floats? Well this instructable will show you how to make a tire valve into a pool float inflater so you can fill them conveniently at any gas station or with any tire chuck.
Step 1: Materials
You need the following materials
1 3/8 hose barb. 3/8 is actually too large to push the safety valve open meaning it will take a bit longer to fill things, but you won't have to hold it.
1 3/8 hose clamp
1 tire valve
1 piece of tubing mine was unused gas line I had lying around
1 3/8 hose clamp
1 tire valve
Step 2: Tools
Tools you will need
2 pairs of pliers.They do not need to be needle nose.
1 screw driver probably flat head
1 exacto knife
not shown but very handy is some olive oil or pam so the valve will go in to the tube easier.
1 exacto knife
Step 3: Cut the Bell Thing Off
Take your knife and cut around the stem right above the bell. This may take a while. After you cut through take your two pliers and pull the bell thingy off. Twisting it around helps too.
Step 4: Cut Your Tube and Attach Everything.
Cut about 2-3 off your tube slide one clamp on the side you want the valve to be on. Insert the hose barb on the other end and push it on, It won't need a clamp due to the barbs on the inside of the tube.Put some olive oil or pam on the stem and push that in and secure it with the clamp.
Step 5: Done!
Now you can fill your floats anywhere!
