Infrared Pen
Intro: Infrared Pen
Hello,
We are the first group of the project Design For (Every)One ( http://designforeveryone.howest.be/ ).
This is a collaboration between Howest, Ugent and the Industrial design Center.
This instructable is about building an "Infrared Pen", it offers a firm base where you can personalize your "Pen" to fit all your needs.
We use this IR Pen to interact with a Smartboard. We made this smartboard with a Wii Remote Controller (which tracks Infrared light) that recognises the position of the IR pen. Online open software converts this movement, which then can be used as the movement of the computer mouse.
With this simple technique, it is possible to make a smartboard for less then 40 euros.
This will be the main tutorial where we focus on making the Infrared Pen.
TEAM : Bert Boute, Ward Meeus, Sarah Carbon
PROCESS : http://activitycenter2014.blogspot.be/
STEP 1: Accessories
To build the pen, we use existing components which you can buy at the local DIY store (Brico, Euroshop, Electronic store, ...)
Components:
- Two pocket flash lights (with leds) 2.50 euro a piece
- Two infrared leds from minimum 100 mA
- Two normal color leds or those from the flash lights
- Two small electric conductors
- Small monostabel switch
The costs of the electronic components are in total 5 euros. The other accessories on the picture above are the inside parts of the flash light.
This means that we can make the pen for only 10 euros or less.
STEP 2: Disassemble + Drilling Holes
DISASSEMBLE
The most important things we need are inside the Original Flash lights. This means we need to disassemble the whole thing.
First we disassemble the lights head, because we will need all the inside components later. We need 1 pen with both sides sending IR light, so we need the light head two times. This means we have to take of the second lights head too and do the steps below.
Second of all we take out the fixing ring. This ring provides a fixation but also conduction (this will be explained later).
Afther taking out all the parts, we can start with disconecting the leds from the little PCB with a soldering iron.
Last off all we need to disassemble the backswitch. This is a bistable switch that we will need later. (On the picture on the left side, next to the monostable switch on the right side). We only need to do this on one light (we need just one bistable switch).
DRILLING HOLES
We need to drill 2 small holes in the tube for the position of the 2 switches. Try to drill with a fixed drilling machine, this makes the hole straight and in the correct position. Afther drilling, use a dremel to work the edges.
We also need just one tube, so there no need to drill the holes in the second light tube.
STEP 3: Solder
The next step is bassically just solder the leds and the ground contact.
With 4 leds we need one color led and one IR led on each side. The position of the IR led is important, the color led may be placed the way you want.
The fuction of the color leds are to indicate if the IR leds are working.
The IR led (black) must be placed in the middle of the PCB. Otherwise it will not send its infrared light in full capacity. Make sure the leds are connected with the plus and minus in the right way.
Afther this we need to connect the PCB with the housing (thread). We do this using two small conducting wires.
We bend a little corner to them en solder them to one of the four spots on the side of the PCB. Make sure that they make contact with the housing case of the light head.
At last we drill a little hole in the middle of the plastic assurance. This provides a little space for the IR led on that position.
Now that everythings is fixed we can return the PCB, along with the other parts, back in the light head.
STEP 4: Battery Holder & Switches
Here comes the hardest part.
We are rebuilding the battery holder to a super compact (with switches) inslidable component.
First we need to take out all the batteries en take one batteryholder away (later to fix the switches). We take this holder away by taking away the plastic material with a filing device. Take away just enough material untill the bistable switch fits in perfectly (picture 2). The monostable switch can be attached on top of the bistable switch. Make sure that the switches match with the positions of the drilled holes in the tube.
After positioning the switches, it's basically just following the wiring diagram from the picture. We need to make contact between the plus and minus of the battery holder (yellow wire). Also contact the switches to the minus side of the batteryholder.
After contacting the switches, we soldered a spring on to the end of them, to make contact with the housing case. We bend the spring a little up so the contact is ensured.
It is hard to explain all this detailed electronics, because every flash light you buy is different. The flash light we bought is normally standard. But if you make sure that the wire diagram is correctly attached, normally the leds will work.
IMPORTANT
IR light is not visible by the human eye, or at least very bad. When you check if the IR leds are working, you simply look through your Phone camera and point it to the led. Then you can see clearly if the IR led works or not. Also if the color leds are working, the IR leds will work to.
When your electronics work, you just need to put back the whole batteryholder into the tube. Now there's a problem: The switches are in the way to slide it properly into the tube. This can work perfectly if you push down the big switch and then slide it into the tube. Make sure that you first slide it in the tube NEXT TO the holes for the switches. When it's deep enought, just rotate the thing and the switch will click up out of the hole.
As you know, we have 2 sides of the light. De first side can be fixed just by rotating it over the thread. This is the side where you can replace the batteries if necessary. The other side will be completely fixed with glue, so there's no possibilty to make it open anymore.
To fix the other side I simply clamped it on the tube with two-component glue between it.
STEP 5: Protection
In most cases this protection won't be necessary, but in our it did. We made this pen for a client with mental disabilities. She breakes everything she gets in her hands so protections was really a requirement here.
The protection we used can also serve as an aesthetic value.
The best flexible material for protection is a bicycle inner tire. Make sure the tire is from an ordinary city bike, not from a racing bike (tire is too small) or mountainbike (tire is too big).
Search a tube that has a smaller diameter then the pen and slide the tire over this tube. Personally i used the heck of the door, but ofcourse it's not the same for everyone.
You need this to roll up your piece of tire, otherwise it is imposible to slide it over the IR pen (trust me i've tried). When your tire is rolled up you pull it a little over the IR pen and slowly roll it off.
Watch out! do not use the whole pen directly. You still need to replace the batteries and it wouldn't be possible to get it over completely.
Use the biggest part of the pen (with the glued part) and roll the tire over the whole thing. After this is done, just cut away the other piece of tire on the end.
After this, put back on the light head on the other side (thread) and slide a smaller piece of tire over it. (not necessarry with rolling it).
If you want, you can make the tire a little longer and bend it over the edge. Afterwards you can glue it directed to the center (like our product).
Finally we cut out a small piece of tire to make the switches visible.
Now your Infrared Pen is finished!! You can find the tutorial to use the IR pen with the smartboard on
3 Comments
michaelgc 9 years ago
I would love a video of this working. I am a middle school math and stem teacher and I was thinking that this would be a cool stem project that would then help my math class... Thanks
ybenzekri 9 years ago
jessyratfink 9 years ago
This is fantastic - can't wait to see the pen and smartboard together!
