Inkscape + Silhouette (Ubuntu/RPi)
Intro: Inkscape + Silhouette (Ubuntu/RPi)
There is already a plugin out there to control the Silhouette through Inkscape, but we had trouble finding directions for Ubuntu.
This Instructable shows tested steps that can get a Silhouette working using Inkscape software on Ubuntu and RaspberryPi.
First, you'll need Inkscape:
https://www.raspberrypi.org/forums/viewtopic.php?f...
This is part of a Silhouette Portrait Group Build with Instructables at Knox Makers.
STEP 1: Get the Plugin
We detailed steps here:
https://knoxmakers.org/wiki/Silhouette
Thanks to Doug and Jondale for throwing together succinct technical steps here.
STEP 2: Open Inkscape
After you have committed the changes to the lp group and Inkscape by logging out and logging back in, now open Inkscape.
Get a simple design ready to test out.
Turn on your Silhouette.
Using your SVG image, go to Extensions >> Export >> Send to Silhouette.
There are some settings to try out, but just go ahead and go with the default settings to see if Inkscape can control your Silhouette now.
STEP 3: Enjoy!
If all went well, you should now be able to control your Silhouette using Inkscape.
2 Comments
scooterdaveuk 7 years ago
Excellent thanks. Works a treat, though the aspect is messed up - at least my laptop is talking to the cutter though
procastino 8 years ago
I was looking just for this info! Thanks! I guess this should work on the Silhouette Portrait as well as on the Cameo?
