Inkscape to Embroidery Machine
Intro: Inkscape to Embroidery Machine
This instructable will help you get from Inkscape to your Embroidery machine.
STEP 1: Install New Features
First Open Inkscape :)
(If you have NOT installed the new features do this step)
*Go to the extension tab and look for Ink/Stich -> English -> Click Install add-ons for Inkscape
*A black screen will appear and wait until a little box to appear and click install
* Close Inkscape overall and reopen it (This restarts it)
STEP 2: Design and Commandments
Import and start a new design
Start adding commands ( Wich will tell the program what you want outlines and filled in or ignored)
Look for Ink/Stich -> English -> Commands -> Attach commands to select object
A little screen will appear with all the boxes necessary
Check off the boxes that you want to apply to your design (Make sure you have an object chosen or nothing will happen)
STEP 3: Start, Pause, Stop, Cut
These little extensions will appear and they show you where the stitch will Start, where it is going to be Cut, where it is going to stop, and finally where it will stop overall.
*You can move around to change were these different places will be placed.
STEP 4: Simulation
Click Ink/Stich -> English -> Simulate
A little screen will pop out and show you a video of how the machine will sew in a virtual world
( Make sure it all looks good to you)
STEP 5: Download
When you download a file download it as a Pes.
Export it to a flash drive and take it to the machine.
STEP 6: Embroidery Machine
Based on the machine you have followed the instructions to insert clothes and be ready to sew.
Make sure you have the right hoop size.
To check hoop size click the circled icon that's on the machine's screen.
Before starting check all the threads and make sure you have enough.
Insert USB to Embroider machine. (Designer Topaz TM 40, Husqvarna, VIKING)
STEP 7: Insert USB File
On the matchine to import a design look for the File Manager Icon. (It is a little Folder)
File Manager -> a screen will pop out empty and ontop a box that says File -> Click it and USB will appear -> Click USB and look for your design (Press and Hold) to import the file.
STEP 8: On Screen Edits
Once on screen, move around the design in the desired place and edit it if you wish.
Click on ALT.
Rotate-> It will rotate design 90 degrees
Position -> It will move you design in small increments
Scale -> It will make your design bigger or smaller in scale
Zoom Option Pan -> How close the design should be
STEP 9: GO!
Once everything is done press GO! which will appear on the bottom left corner of the screen
STEP 10: Press Start
Follow any instruction the machine gives you (For Example: Take hoop on and off )
Press Start and watch your design come to life ( Stop it if anything seem to be wrong)
14 Comments
needlethreadcofl 2 years ago
raifdsgn 3 years ago
Any help,I am ready to buy it
Newtosite 3 years ago
ARSteAm 4 years ago
AindreaB 5 years ago
am_ 5 years ago
Locomiguel 5 years ago
I don't know if you are still interested in this or if you worked it out, I am not very tech savy, being a plug and play kinda guy, and it was obvious from the answers that the author AM and Ysabeau were much more so than I. so it took me a while, and my daughters help to work it out.
First I went to this web site:https://github.com/inkstitch/inkstitch/releases/tag/v1.25.0 , as noted below and hunted for the InkStitch embroidery extension.
I downloaded the one I needed for my computer, it offered up linux, Mac (-osx-), and Windows (-win32-). in German (de), French (fr) and English (en).
I used the windows and just downloaded the Zip file to my download folder.
I then unzipped the file to my document folder.
I went to the file explorer program and loaded in the information as presented below by Ysabeau: For Windows: C:\Users\Miguel\AppData\Roaming\inkscape\extensions, that I had gotten from inkscape at edit>preferences>user extensions....Copy and paste to file explorer. Getting the path from inkscape guarantee's your name and info on your computer
I hit magic reload key. lo, and behold, a file opened up and told me it was empty.
I opened went to my documents, opened up the extracted file, copied everything in it and pasted it to the empty file.
As stated, I am not very tech savy and I kept trying to paste the whole extracted file to the extension file. Didn't work. Daughter Pointed out I had to open file and copy the material and paste it all to the extension file.
I did, closed the file, closed Inkscape, reopened Inkscape and it was all there.
I really look forward to using this particular technique to create machine embroidery pattern as the damn husqvarna viking diamond pro program is really complicated (for this curmudgeon anyhow) to use. So Thanks to AM for the instructable.
Ysabeau 5 years ago
For Linux: home/<username>/.config/Inkscape
For Macintosh, somewhere in a directory of: users/<username>/Library
For Windows: C:\Users\<username>\AppData\Roaming\Inkscape
<username> is the name of the user (obvious) so for example, if your username is "carrot", the profile should be, for Linux, in home/carrot/.config/Inkscape.
More information here:
https://inkscape.org/gallery/=extension/
JessyInk is another extension.
Ysabeau 5 years ago
I'd love to translate it in French for either my website (https://aiguilles-magiques.com) or for this website https://linuxfr.org. Can I do it?
am_ 5 years ago
Ysabeau 5 years ago
https://dutailly.net/d-inkscape-a-une-brodeuse
Obviously, I linked to your instructable.
Thank you. I also wrote a tutorial before on how to add an extension to Inkscape, it is in French:
https://dutailly.net/ajout-d-une-extension-dans-in...
Penolopy Bulnick 5 years ago
Do you have any pictures of finished embroidery projects you have done this way?
am_ 5 years ago
