Introduction: Install IJDMTOY LED Light Bar for 2006-2008 Ford F-150
If you're looking for an LED light bar to mount to your lower bumper on your 2006-2008 Ford F-150 then look no further. This iJDMTOY Ford F-150 LED light bar with lower bumper grill mount is perfect for those looking to fill up that space in their grill. With these steps you can check your new truck light out and use them for whatever you need.
Step 1:
Remove the two lower damn bolts by using an 8mm socket.
Step 2:
Then, remove the upper bumper bolts on each side using a 10mm socket.
Step 3:
Using a flat head screwdriver, remove the factory clips from the upper bumper brackets.
Step 4:
Place the drivers side bracket in the bumper.
Step 5:
Use the factory bolt to mount the lower air dam.
Step 6:
Using the supplies bolts, nuts, and washers, bolt the mount to the upper bracket.
Step 7:
Tighten the upper and lower bolt using a socket and wrench. Slide the light from the bottom and then hand tighten the bolt it to the drivers side and passenger side. Repeat the previous steps for the passenger side bracket.
Step 8:
Adjust the lighting positing and then tighten it to the desired angle. With a few simple steps you can be enjoying your iJDMTOY Ford F-150 LED Light Bar..
