Introduction: Install A-Pillar Mount LED Pod Lights on 2018 Jeep Wrangler JL
This tutorial will show you how to install the A-Pillar Wrangler LED pod lamps on the 2018 Jeep Wrangler JL. This LED podlamp kit is ideal if you are just getting into custom mods and additions. With low commitment, these LED pod lights are easy to install and have a high output of LED light for its size. These LED pod lights will also improve the adventurous outdoor look of your new Jeep Wrangler.
Step 1: Remove the Torx Bolts From the A-Pillar Area.
Step 2: Use the Included Nuts to Use As Spacers.
The inner mounting hole will use a smaller nut while the outer mounting hole will use a bigger nut.
Step 3: Bolt on the Pod Light Mounting Brackets Onto the A-Pillar Area.
Thread bolts through the mounting holes and line them with washers. The A-pillar brackets you see in the pictures are prototypes. The support brackets you receive will be different than what you see here but the installation process will be the same.
Step 4: Final Steps
Preassemble the LED pod lights with their U-shaped brackets.
Mount the LED pod lights onto the A-Pillar support brackets. If the LED lamps do not sit straight with the A-pillar brackets, you may push down on the LED pods until it lays parallel.
Wire the LED pod lights using the relay wiring harness.
Test them to make sure both units fully light up. Once you confirmed that they have, you may now enjoy your Jeep Wrangler JL's brand new pair of A-Pillar LED pod lamps!
Find this and more offroad truck LED lighting at iJDMTOY.com.
