Introduction: Install GMC Sierra 1500 1500HD Cubed CREE LED Fog Lights
This tutorial will show you how to install the 20W high powered CREE cubed LED pod lights on your 2003-2006 GMC Sierra 1500 or 1500HD. The entire kit comprises of (2) 20W LED pod lights, a pair of mounting brackets and a set of 9145 (H10) pigtails. Installation will involve any modifications and will be a direct replacement process.
Step 1: Take Out the Screw in the Leveler Circled in Red Below.
This will loosen your OEM fog lights.
Step 2: Slightly Pull Apart the Stock Bezel to Release the OEM Fog Lights.
Step 3: Preassemble the Cubed LED Pod Lights.
Secure the rectangular metal bracket piece onto the u-shaped bracket with a nut and bolt combination.
Follow our guide on how to preassemble pod lights with brackets.
Step 4: Bolt the Cubic LED Podlamps Onto the Leveler by the Long Bracket.
Adjust the LED pod light as you desire. Fully secure the screws when you are finished adjusting.
Step 5: Connect the Wires of the LED Podlights to Your GMC Sierra's Factory Fog Light Harness.
Use the included pair of 9145 (H10) pigtail wires to connect the LED pod lights to your fog light harness.
Step 6: Final Steps
Test your LED pod lamps to ensure they fully function. Once you confirmed that they light up, completely mount the stock bezels to your fog light area and close up your wheel well to finish.
You can now enjoy your GMC Sierra's brand new high powered cubed LED fog lights!
Shop for more OEM fit LED running lights at iJDMTOY.com today!
