Introduction: Install IJDMTOY BMW 3 Series LED Turn Signal
The BMW F30 3 series is a very classic and iconic car to buy today. To make your new BMW 3 series stand out some people like to upgrade their rear turn signal lights for better visibility and also for increased safety. This BMW LED rear turn signal light bulb is also compatible for the BMW F32 4 Series but for this installation is on a BMW 3 series but you can also perform these steps on the BMW 4 series as well.
Step 1:
Open the BMW F30 3 Series trunk to locate the rear taillights and look for the two bolts holding it in place.
Step 2:
Use a wrench and remove the two bolts holding the rear taillights in place.
Step 3:
Use the provided green pry tool to gently pry out the light fixture tail lamps and remove it by pulling outwards.
Step 4:
Flip the taillight housing to expose the caps holding the OEM turn signal light bulbs. From the side you will be able to see the stock turn signal bulbs from the side of the tail lamps.
Step 5:
Gently remove the tail lamp cap to expose the stock turn signal bulb and gently remove the OEM turn signal bulb.
Step 6:
Directly install the new BMW F30 3 series LED turn signal lights.
Step 7:
This is how your new iJDMTOY BMW 3 series LED rear turn signal lamps would look like in the housing. Put the tail light housing back in and tighten the two bolts to secure the rear tail lamp housing to the BMW 3 Series.
Step 8:
Test to make sure the 7507 LED Bulbs rear turn signal lamps turn on and enjoy your new BMW F30 3 Series LED blinker lamps.
Step 9:
This was a very simple install that makes your Bimmer look brighter and more noticeable. As you can see, there were no modifications needed to fit your new BMW 3 Series LED rear turn signal and now you can enjoy your new LED rear blinkers in no time at all.
