Introduction: Install IJDMTOY Hyundai Veloster Tow Hook License Plate Mount
The Hyundai Veloster is a great affordable car with a very aggressive design. One of the best upgrades for the 2011-up Hyundai Veloster a tow hook license plate adapter, and iJDMTOY has a specially designed model that does not require any modification. Many Hyundai Veloster owners choose iJDMTOY Hyundai Veloster Tow Hook License Plate Bracket because of the straightforward installation and the sporty look that comes with the front license plate mount.
Step 1:
The first step is to first remove the tow hole cover.
Twist and pull the tow hole cover to release it.
Step 2:
Get your brand new tow bar and carefully twist it in straight into the tow hole opening. This does not need to be tightly twisted on, just enough to secure the license plate so that it will not move around.
Make sure to twist the tow bar in perpendicularly so the threading can latch on.
Step 3:
Now it's time to mount the adapter plate. Get a locking washer included in the package and insert it into the screw before you screw the adapter plate onto the tow bar.
These adapter plates are designed with curves so as you install it on to your car, you can angle it slightly so the plate is parallel with your cars bumper. Adjust the angling of your mounting plate so that it follows the curve of the bumper.
Make sure that when you secure the mounting plate onto the tow bar and the rest of the components in future steps that YOU DO NOT USE A POWER DRILL. Using a power drill will damage the tow hook license plate adapter, so we advise that you hand tighten the screws instead.
Step 4:
Now you can mount the license plate onto the mounting bracket. Screw in your license plate and secure it onto the mounting plate.
Step 5:
This is a perfect and simple way to change up your Hyundai Veloster. You can see just how easy it was to relocate your front license plate and have an aggressive look to it at the end with your new tow hook front license plate adapter mount. Installation took only a few minutes so it's absolutely not time consuming at all, giving you plenty of extra time to drive onto the streets and show everyone your new no drill tow hook license plate bracket.
