Introduction: Install Mazda 3 LED Daytime Running Lights
The Mazda 3 (Axela) is known to be a sporty sedan that has quite a large following all over the world. There are tons of upgrades for it, including a new set of Mazda 3 Direct Fit LED Daytime Running Lights. This LED assembly replaces the fog light bezel to give you a whole new flashy look.
Step 1:
Use a pry tool to remove the stock fog lamp bezel.
Step 2:
Replace back with the LED daytime running lights.
Step 3:
Route the wires up to the engine bay and connect the DRL wires to the module box.
Step 4:
Tap the red wire to battery positive terminal and black wire to battery negative terminal.
The blue wire is optional to headlight positive to turn off the LED DRL.
Step 5:
Step 6:
Test to make sure everything works.
Step 7:
Mount the module box and tie the connectors to prevent them from getting loose.
Step 8:
You can see that installing these Mazda 3 Direct Fit LED DRL did not involve any modification so you don't have to risk drilling into your bumper and damaging you car. After you test your new LED assembly, be prepared to have lots of people ask you questions about your upgrades!
