Install Official Google Chrome OS on PC / Laptop With Play Store and Linux for FREE !
Intro: Install Official Google Chrome OS on PC / Laptop With Play Store and Linux for FREE !
Hey Guys, Today in this video I am going to install full fledged chrome os on pc / laptop that has Google play store inbuilt and has linux crostini support, chrome sync, Google assistant and many more exciting features.
it is highly recommend to watch the video for all the detailed steps ,but i added step by step pictures in this instructables.
*Credits* Special thanks to the Developer sebanc from Paris, France who helped me a lot. https://github.com/sebanc
STEP 1: Downloading Resource Files
**Download Links**
1) Linux Mint https://www.linuxmint.com/download.php
2) Rufus https://rufus.ie/
3) Brunch https://github.com/sebanc/brunch/releases
4) install.sh https://raw.githubusercontent.com/shrikant2002/Ch...
5) Official Chrome OS recovery image (rammus) choose the latest one here https://cros-updates-serving.appspot.com/ or direct link for rammus recovery r80 version (extract it and rename it "rammus_recovery.bin") https://cros-updates-serving.appspot.com/
if the above link is down you can download from here https://sites.google.com/view/brunch-project
Make sure to download all files and extract or rename as per details.
STEP 2: Making the Chrome OS Bootable Image
To make bootable Linux image we are going to use rufus tool
Follow each step as shown in pictures
you can use 8,16 or 64 Gb storage device for bootable drive.
STEP 3: Getting Your Bootable Device Ready!
Rename the downloaded recovery file as "rammus_recovery.bin"
make sure to extract other files and paste it into our bootable device .
STEP 4: Booting Linux for Chrome OS Installation
First plug in bootable device
Get into bios by pressingF2
In bios select boot option as "UEFI"
Save changes and reset
Press F12 for boot drive selsection
select out EFI1 USB1
Press Enter
Select first option "Linux Mint Bootable...."
You will success fully boot into Linux, for one step chromeos installation.
STEP 5: Installing Chrome OS !
After You will success fully boot into Linux, for one step chrome os installation.
Connect to wifi by putting password.
Click on file and locate our chrome os folder
Right click and open terminal
Into terminal type "sudo sh install.sh"
when it will ask to wipe your drive Type "Yes"
There you go ,chrome os is installed ...
STEP 6: Booting Up Chrome OS
Now remove our bootable device
and boot up your device
And Enjoy your Full fledged Chrome OS !!!
STEP 7: Chrome OS Installation FAQ
**Chrome OS Installation FAQ**
1) Is this the same as Neverware Cloudready, Flint OS or Fyde OS ? No its not, Its full fledged Official Chrome OS including Android Apps, Linux, Google Assistant, Chrome Sync which is not available usually in this releases.
2) I'm stuck on google logo. Your recovery image file may be corrupted. So re download it and follow the procedure again.
3) My hard drive has name different than sda. You can edit the install.sh script and replace "sda" to your hdd name. or enter the following commands line by line in terminal and replace your hdd name with "sdX"
sudo apt update sudo apt install pv sodu apt install cgpt sudo chromeos-install.sh -src rammus_recovery.bin -dst /dev/sdX
4) I am not able to boot up. Please check your bios settings and disable secure boot, CSM, Legecy mode & turn on UEFI Boot option
5) I want to dual boot Chrome OS with Windows 10. Please let me know in the comments down below so I can make a separate video for dual booting chrome os with windows 10.
6) Linux apps (crostini) are not working at all, how do i fix it? Go check if you have enabled all virtualization related option in your BIOS (Ex: "Intel Virtualization", "VT-x", "VT-e" etc...) (you should)
Still if you have problem ,watch the video or comment on the video
14 Comments
slivka 3 years ago
talbouy 3 years ago
peremayol 3 years ago
Steephen mathew k 3 years ago
DavidW81 3 years ago
Is it possible to skip or do not show this running script on booting up? Thanks.
ajay3468 3 years ago
I am facing two errors after following your procedure.
Errors : no partition available
Errors: please load the kernel first
jassun9 4 years ago
any help with that
thanks
abdoulgaf 4 years ago
charliefung 4 years ago
Go thru all steps and saw the "Chrome OS installed" on my laptop. After machine re-start and saw the "Missing OS" error message.
Any advice!
Laptop: Asus Ultrabook UX31.
Kedar Nimbalkar 4 years ago
https://youtu.be/FEY9MtznYGU
rpg072 4 years ago
I have the same issue as Charliefung. All process works, but on reboot it shows "Missing OS". I have HP nc6400 32 bit.
Ideas?: anything to do with TPM ? Or may be Rammus does not work with older machines? Also, in project croissant speaks about using two images (eve and Caroline) due to TPM. Any clue? Thank you and congratulations for the work
jassun9 4 years ago
