Install Quality Sliding Doors │ Directpro.ca
Intro: Install Quality Sliding Doors │ Directpro.ca
So, you have finally decided to install new doors! Now the question is which door type you will select? Whether you should go with French doors, patio doors or sliders- this decision will depend upon your home’s architectural design, prevailing trends and the surroundings as these factors are responsible for ensuring curb appeal of your home.
The fundamental difference between patio doors and sliding doors is that patio doors can swing while, sliders glide. Sliders have one fixed and one matching panel that can slide upward and downward to brighten the room and allow fresh air to enter. For patio, there is a pair of doors that has one hinged or fixed panel that swing inward or outward, according to the type of door you have chosen.
There is a certain kind of patio door that is called French door where, the term typically means a pair of glazed patio doors, which are hinged at opposite sides and joined each other at the center. Patio doors and sliding doors are sold with complete accessories, including threshold, jambs and the essential weatherstripping. The door makes sure energy efficiency while, the hardware is designed as an important part of the system.
A worth mentioning fact about French doors is that they are not only manufactured for exterior use- they can be used internally to adjoin one room to the other, separating them when closed or give generous access across the rooms when opened.
Classic French doors have more than one glass panes (known as lites) that are divided by wood muntins. The division ensures that every glass pane has a separate, strong and sturdy built so that it can last for a longer period of time.
Though, French doors are available at premium as well but, most of the manufacturers sell doors with faux lites. They have snap-in wood grills or grilles that are fixed between the dual glazing panels. They enhance the overall appearance but tend to be cheaper and easier to handle as compared to real divided lites. Some grills versions are capable of creating an evenly-spaced lite gridwork in pairs of six, eight, ten or twelve whereas, others go with horizontal panes, consisting of four, five or size lites.
Another important thing to mention is that every manufacturer offers different doors in varied sizes. Most of them have set the minimum width at 16 inches while, minimum door height is 60 inches however, you can make changes according to your need. When it comes to the thickness, it is either 1-3/8 inches or 1-3/4 inches. There are 3 or 4-door-wide option available in the market that has maximum width of 16 feet. New version of sliding doors has an added feature to curve at a 90-degree angle.
Now that you have enough information about different door types, it’s time to log on to http://directpro.ca, purchase the selected door and ask their experts to install them.
