Introduction: Install a Webserver on Raspberry Pi.
This guide briefly explains how to install a webserver on your Raspberry Pi.
First you should enable ssh. A guide is found here:
https://www.instructables.com/id/Use-ssh-to-talk-with-your-Raspberry-Pi/
You'll need:
1 Raspberry Pi
(connected to a router and the Internet)
When the webserver is installed you probably want to add files with ftp:
See step 2!
If you want to make the webserver visible on the Internet look here:
https://www.instructables.com/id/Raspberry-Pi-as-webserver/
Step 1: Install Apache
Connect to your Raspberry Pi.
If you havent set up ssh a guide can be found here:
Run the commands:
sudo apt-get update
sudo apt-get install apache2 php5 libapache2-mod-php5
Now your Raspberry Pi should display (if you open it in your browser):
It works!
If you are uncertain of address type ifconfig in your ssh-window. Should be 192.168.1.12 for example.
Step 2: Add Files to Your Raspberry Pi With Ftp.
Install a Ftp-client on your PC.
For example:
http://www.coreftp.com/download.html
Open a connection to your Pi.
Files are found underthe catalog /var/www
... if you have followed the previous steps.
My Raspberry webserver can be found here:
http://213.65.123.101/qr - A QR business card generator.
http://213.65.123.101/whoiam/ - all you want to know about what google knows about you.
May the Pi be with you!
7 Comments
7 years ago
I can't connect to the FTP, what can I do ?
9 years ago on Introduction
Didacticiel très sympa. Par contre est-ce qu'une base de données à été installée et si oui comment l'administrer ?
Thanks Drk_Chpr! If you are in the start blocks to administer a database, I suggest you have a look at Postgresql! http://www.pontikis.net/blog/postgresql-9-debian-7...
hello.. i need the video for install a webserver on raspberry Pi, step by step.. anyone can help me..?
I think you can follow instruction above, but maybe this can help:
http://lmgtfy.com/?q=youtube+install+web+server+on... ;)
10 years ago on Introduction
Tnx Helder4u!!
10 years ago on Step 2
niice :)
