Installing WAMP Server
Intro: Installing WAMP Server
How to install WAMP server so you can use Apache, PHP and MYSQL. This is a prequest to Beat the School Website Blocking System.
STEP 1: Download WAMP
Download WAMP server here. Select save or run. Click open. After that follow the next steps.
STEP 2: Configuration
Just press next.
STEP 3: Configuration
Selcet "I accept" and Press next.
STEP 4: Configuration
Select where you want to save it. If you can't decide just leave it as it is. Then press next.
STEP 5: Configuration
Type the name you want to appear on the Start Menu. Then Press next
STEP 6: Configuration
If you accept this, your computer will be quite slow on startup but do what ya want. Then click next
STEP 7: Configuration
Just let this one run.
STEP 8: Configuration
Type your email (I suggest you make a new email account from hotmail or something). Leave the next window as localhost unless you know what you're doing.
STEP 9: Final Config
Just press Open and then finish and ur done!!!!
12 Comments
AbhishekR62 7 years ago
Hi, I have made a written version of Intalling WampServer on Microsoft WIndows here, http://technospace.xyz/install-wamp-server-windows-7810/ I am sure it will help out users to install this , the steps on mine are pretty simple and easy.
JemmyL 8 years ago
Thanks for sharing this. It will help many. I too came across such where they explain in detail. I want to share that here http://www.allinformer.com/how-to-install-wampserver-on-windows/
clcbell 9 years ago
Ok so I downloaded, followed typical install (as above). Once installed I got error message: can't run because missing MSVCR110.dll. Said to run the install again, so I did. Same thing. I uninstalled all componenets, downloaded again. Reinstalled and got same message. What am I doing wrong?
KapilK3 8 years ago
Download file MSVCR110.dll and copy to the system32 folder
that's all.....
HoangTuMuaHe 9 years ago
Thank.
I tried wamp, xampp and even mamp and finally play with Laragon (http://laragon.org/). It supports Memcached, Redis that are my tech stack.
Funny I love Aragorn also.
ksho1 10 years ago
Clear, Simple and Helped.
Thanks Dude...
priti0901 10 years ago
http://code.freefeast.info/php-tutorials/setting-up-the-environment-for-php-php-tutorial/
Computothought 13 years ago
My wampserver install: https://www.instructables.com/id/Home-Automation-MSWindows-XP/
If you use ddns, you can get a domain free for a limited time.
Once you start using a web server, you will wonder why you never used one before. I run my private apache web server on an old an old pII. It is currently running Ubuntu though I prefer debian when I am not running centos. I had it on I think ubuntu server 6.x and have done in-place upgrades as they came along the way to 9.x. (i.e. no reformatting or disk wiping). This is an example of the actual web pages i run on it. https://www.instructables.com/id/Uses-for-your-own-private-cloud/ I have since added doing home automation on it. Keep finding uses for that legacy computer. Microsoft Windows Supporters said I should have thrown away a long time ago. It is not what you use, but how you use it.
hem36 14 years ago
MARCREED 14 years ago
34will 14 years ago
basit006 14 years ago
