Installing a New Virtual Host in the Apache Web Server
Intro: Installing a New Virtual Host in the Apache Web Server
The purpose of this tutorial is to walk through the process of configuring and initiating a new Apache web server virtual host. A virtual host is a "profile" that detects which DNS host (e.g., www.MyOtherhostname.com) is being called for at any given IP address. It is possible to narrow this further by only coupling IP addresses and hostnames in the virtual host configuration, but I will skip that and assume that every IP address the server has is permitted to access the virtual host.
This instructable was made specifically with a Debian server running Apache 2.2.x.
STEP 1: Login and Get to the Right Place
First, log in and change directories to your configuration directory. In most sane servers, this means logging in as a user with superuser privileges, and going somewhere in /etc/
$ ssh me@myserver.com
Password: exciting_password
Welcome!
~$ cd /etc/apache2/sites-available
Welcome!
STEP 2: Create the Virtualhost From a Default Template
Usually I keep a default file around, which I copy to a clipboard and paste for use. From that default file, you can edit the specifics. Below is a reasonable default file you can refer to, which assigns the document to a Drupal directory:
$ pico MyOtherHostname.com
<VirtualHost *:80>
ServerAdmin Admin@server.com
DocumentRoot /home/web/drupal/drupal-6
ServerName www.MyOtherHostname.com
ServerAlias MyOtherHostname.com *.MyOtherHostname.com
RewriteEngine On
RewriteOptions inherit
CustomLog /var/log/apache2/MyOtherHostname.log combined
</VirtualHost>
Needless to say, you can make whatever customizations you wish according to the information found in the Apache 2.2 virtual host documentation.
<VirtualHost *:80>
RewriteEngine On
</VirtualHost>
STEP 3: Enable the Site and Restart Your Server
Now it's time to enable the site and restart the server. Debian has a few cool server management tricks here:
First, let's enable the site:
$ sudo a2ensite MyOtherHostname.com
Site MyOtherHostname.com installed; run /etc/init.d/apache2 reload to enable.
$ sudo /etc/init.d/apache2 reload
Reloading web server config.... PID#
And now you should be able to access the site so long as the DNS server points it to your server.
For Drupal sites, I often take this opportunity to add the cron.php file to my crontab before I forget:
$ sudo pico /etc/cron.d/drupal
2 0,5,10,15,20 * * 1-6 nobody curl --silent http://MyOtherHostname.com/cron.php
That's it! Congratulations!
tarek : )
tarek : )
4 Comments
admin 15 years ago
Tarek_Loubani 15 years ago
Computothought 12 years ago
uranus_b_hurtin 14 years ago
The design minimizes the edit work in httpd.conf.
