Instanly Remove Images Background for Mac
Intro: Instanly Remove Images Background for Mac
Tutorials: Instanly Remove Images Background with Super PhotoCut
Super PhotoCut interactive cutout tool separates a detailed foreground object from photos and remove image background for Mac. With our proprietary best-in-class algorithm masking tool, you can instantly remove complex background from image for Mac and make them transparent with just a few clicks.
STEP 1: Target Object Rectangle
Mark the object with a rectangle to obtain the desired result.
Correct: The rectangle is same size as target object.
Common Problems: The rectangle is too large. Too much noise is included.
Common Problems: rectangle is too small to target the object.
Make sure to minimize the rectangle scope. When you select the target object, remember that the rectangle should be SAME SIZE as target object.
STEP 2: Marking Rules
Anything you mark will either be fully in the result, or fully removed from it. This is why it's so important to not go outside the lines - the result is guaranteed to be wrong. Stay Well Within The Lines.
Green = 100% Foreground = Always fully kept in the result
Red = 100% Background = Always fully removed from the result
Eraser = Algorithm decides = Algorithm will figure out exact edge and make the background becomes transparent.
STEP 3: Mark Foreground
Use green marker to mark part of the foreground that you want to reserve. Use red marker to mark part of the background that you want to remove. Correct : If the target object could not be displayed correctly in the rectangle, you need to use Green marker and red marker seperately.
Common Problems: Carefully mark all areas.
STEP 4: Don't Highlight
The green / red tools are not highlighters, and using them as such will produce a terrible result It is not necessary to carefully select the area, just need draw some lines with GREEN and RED Marker. Stay well within the foreground or background, and don't mark too much.
Common Problems: Go outside the lines.
