Instant Hammock
Intro: Instant Hammock
Here's how to make a hammock in a minute from a sheet or any big piece of cloth.
It's the simplest method from my "Instant Hammock" article in Make Magazine Issue #9.
I used the program "Avd Video Processor" to make these animated gifs from video.
Now on Know How! Click on the steps above for more details.
Do you like this Instructable? Digg it!. Then check out episodes one, two, four, five, six, and
seven!
First bunch up the ends and tie knots in them as shown.
If you don't have much cloth, are skilled with rope, or don't care if you fall you can skip this step.
seven!
STEP 1: Tie a Rope to Each End With a Lark's Head Knot
just like this, or tie whatever knot you like best.
If you don't fall it means you did it right.
STEP 2: Hang It Up, Get In, and Relax
In utter comfort.
Rachael Norman Demonstrates.
For extra coziness pull the hammock around you like a coccoon.
STEP 3: Hammock Workstation for Large Drawings
STEP 4: Danielle Smith Triangular Hammock
Danielle rigged up this swell triangular hammock in her yard in Austin TX.
It's a bedspread tied at the corners to three trees.
Her offspring Rhett Applestone gets his relax on.
STEP 5: Non Instant Traditional Maya Hammock
In case you'd like to make an elaborate Maya style hammock, here are some notes from 2001.
You should probably buy a hammock to look at (and rest in) before attempting to make your own.
Lauro lives at the entrance to Bahias de Punta Soliman in the Yucatan, Mexico.
He weaves hammocks to pass the time. Here he is at work.
He's using a netting needle just the same as the fishermen use to mend their nets.
The string is thin hammock string which is sold in fabric and hardware stores there.
STEP 6: Lauro's Loom
The wooden frame is held together with wedges so he can change what size of hammock he makes. Also so he can remove the hammock from it when it's done.
STEP 7: Starting the Hammock
To start out he winds about half the string needed to make the hammock at the top of the loom at 'a'.
Let's call that the "warp" string, although technically he's "twining" rather than "weaving" and it probably has a different official name.
Then he loads up his netting needle with string and starts to wind it around the first two strands of warp string as shown.
STEP 8: The Pattern Continues
Wrap another turn of warp thread around the frame and go around and around it with your netting needle. The drawing is a little ambiguous (and rough). It's supposed to look like going around and around, not any other sort of more complicated pattern.
There are many styles of hammock. This style gets you the most hammock for the least string. There are some where you wind your string around three or more warp strings at a time rather than the two shown here.
STEP 9: Finishing the Hammock
There are lots of ways to finish a hammock, this is how Lauro did it.
The strings at the very edge are important. If they break it's easy to fall out of the hammock. And hard to get comfortable.
101 Comments
Luciaesk 5 years ago
I love hammocks. I think they are incredibly comfortable, and I enjoy several of them in my home. I take note of the ideas shown here.
Thank you for sharing
southqaw 16 years ago
a03326495 7 years ago
I've found a king size sheet is a good size for an adult. Your local thrift store has used sheets in fun patterns for cheap, just give em a good wash.
TimAnderson 16 years ago
siafulinux 13 years ago
Going to bye a non-fitted sheet to make it better and probably some stronger rope, just to be safe. Now if only I could find an easy way to set this up inside the house. hmm
yoyology 11 years ago
https://www.instructables.com/id/Hammock-Stand-Indoor-Outdoor/
https://www.instructables.com/id/DIY-Hammock-Stand/
...or put some lag eyes into a couple of studs. Though that might be a little extreme.
haptotrope 13 years ago
Steamr 8 years ago
Never mind my parents won't allow this in my room, (they don't want holes in the walls) never the less I made it at a friends house, in his backyard of course.
kthurm 7 years ago
build a stand to hang it from
Steamr 8 years ago
How do I secure the hammock to my bed room wall.
Mr_Altitude 10 years ago
dragonslug 10 years ago
122717 10 years ago
ionut_mystic 10 years ago
You should try some nylon material, or somethin similar. It doesn't weight much and is very strong.
ChippMarshal 10 years ago
Simple yet ingenious!
Meursydotes 10 years ago
122717 10 years ago
Cann0n 10 years ago
janetsellers08 11 years ago
Celina222 12 years ago
