Interactive Jacket for Cyclists
Intro: Interactive Jacket for Cyclists
Interactive Jacket for Cyclists is a fun project where we turn an ordinary jacket into a wonderful interactive jacket which can display turn signals on the back. These turn signals (LEDS) can be activated by using hand gestures (waving your hand). Also it features front and back LEDs for increased visibility for the cyclist.
In this Instructable, we will show you how we made it, step by step and how can you replicate it to make your own jacket.
This was part of course project for Physical Computing at Saarland University taught by Prof. Steimle.
STEP 1: Stuff Needed
Before we do anything, lets make a list of things we would need to make this jacket.
Images are listed in the order of the list
- A Jacket (Obviously. Any jacket would do)
- Arduino Uno (or Lilypad)
- Two 9V Batteries (or one 9V battery and one Lilypad battery if using lilypad)
- Two Accelerometers (if possible, two identical accelerometers are required. However we did not had two identical ones, so we used Sparkfun IMU 9DOF Sensor Stick and Adafruit ADXL335)
- Red LEDs for back lights
- Yellow LEDs for turn signal lights
- White LEDs for front lights
- Perfboard
- Dozen 1k ohm resistors
- 9V battery connectors
- 10k ohm potentiometer
- Four 2N2222 transistors
- Set of wires, very long ones
- Screw headers for connecting the wires to the perfboard
- SPDT Maniture Switch (main on/off switch)
- A box to contain Arduino and the batteries inside the jacket. We used Arduino Sidekick Basic Kit's green box
You can also buy LED strips instead of individual LEDs.
Tools Needed
- Hot glue gun (or sewing kit)
- Soldering Iron
- Shrink tubes
- Sticky notes (for labeling the wires)
STEP 2: Design
The layout image shows the placement of the lights in the jacket, as well as the placement of the accelerometers near the cuffs. You can place the main board (Arduino and batteries) anywhere you want, let it be underneath the jacket.
The reason for placing the accelerometers near the cuffs of the jacket is that, it needs to be near the hands in order for it to detect the hand gestures effectively.
There are two turn signals LED groups for left and right turns, which are yellow LEDs. There is a single group of red LEDs for brake/back in red color and single group of white LEDs in white color for increased visibility.
STEP 3: Circuit Design and Programming
To make this jacket, we need a circuit. The circuit schematic diagram (added figure) shows how different components are connected. You can make the circuit on a breadboard to test it out first (figure is added). And then solder it to the perfboard which can be used as an Arduino shield (Arduino addon, see the pictures). But the wires to & from the accelerometers should be long enough to reach to jacket's cuffs, since we need to install the accelerometers at the cuff (see previous step).
Programming the Arduino
Once you are done and happy with your the circuit, you need to program the Arduino. The program for the Arduino is given in the files section. The program requires two additional libraries
Install the libraries first into the Arduino. Then download the Interactive_Jacket.zip file and open with Arduino to program it.
Early Testing
You can test the working of the circuit by placing the accelerometers on your cuff (see figure) and try waving it. If the gesture is not detected, try changing the potientiometer to change the sensitivity.
LED circuits
We soldered the LEDs in series and parallel combination so that each LED can get 1.5 volts, along with 220 ohm resistors to limit the current.. We are running the LEDs from 9V batteries. But we would suggest replacing the LEDs with LED strips for simplicity.
STEP 4: Assembling
Attaching the Accelerometers Modules
The assembly of the jacket starts with attaching the accelerometers to the inside of the cuff. The modules can be added using hot glue or sewing. The figure shows the how the modules are attached to the inside of the cuff along with wires. Please label the signals/power wires with sticky tape and write the wire names.
Attaching the LED circuits
The groups of LEDs are made using perfboard and can be attached using hot glue. You can see in the figures how each perfboard with LEDs are attached to the jacket. You have to make a hole for the wires to pass through.
LED wires
The wires (LED ones and accelerometer ones) are routed to the main board (Arduino) and fixed to the jacket using hot glue, you can also sew it if you want to. See the figures.
Main Board
The main board comprises of Arduino, the circuit and the batteries enclosed in a container. We used Sidekick Basic Kit as a container :P
Attaching the Switch and Potentiometer
You can attach the switch (on/off) and potentiometer to the green box. But for that we need to make holes for the wires to pass through. We used soldering iron to make holes into the green box, later we hot glued the switch and potentiometer. See the figures
Basically you are done with the assembly step.
STEP 5: Testing It Out!
So you have reached till this step. Everything should be working for now. Your jacket should be complete by now
Try changing the potentiometer to change the threshold value which will make the hand gesture detection more sensitive.
What's more?
Well you can do a lot of improvements to this jacket, such as maybe detect the deacceleration and turn on the back LEDs accordingly, acting as a brake lights. Or perhaps make this out of Lilypad and conductive thread and make it washable.
Good luck!
If you like this Instructable, please vote us for the competitions, thank you
14 Comments
Jorzel23 4 years ago
MeliV1 5 years ago
mujtabachang 5 years ago
If you are unsure about the LED wiring, you can learn about it in this video
https://www.youtube.com/watch?v=QEpmAkw4uE4
jasbirjassi 6 years ago
Great project Sir!
working on this project this error was encountered while uploading project on Arduino Uno. Please help me.
Arduino: 1.8.5 (Windows 8.1), Board: "Arduino/Genuino Uno"
C:\Users\pc\Documents\Arduino\Interactive_Jacket\Interactive_Jacket.ino:5:25: fatal error: SimpleTimer.h: No such file or directory
#include <SimpleTimer.h>
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
mujtabachang 6 years ago
Download the SimpleTimer library from here
https://playground.arduino.cc/Code/SimpleTimer
ravijaiswal 6 years ago
please help me.
Sketch uses 12362 bytes (38%) of program storage space. Maximum is 32256 bytes.
Global variables use 1105 bytes (53%) of dynamic memory, leaving 943 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
prafullaa 6 years ago
Extract the zip file and you will find a folder "Interactive_Jacket". Place this folder in My Documents/Arduino/
Access the program in Arduino, go to File menu>Sketchbook>Interactive_Jacket
ElifK8 7 years ago
Great idea! especially for the night bike riders:) I liked it.
diy_bloke 7 years ago
Looks great. As you are talking about the brake lights as a future improvement, I was wondering what their current function is
mujtabachang 7 years ago
The current function is to blink at some intervals to increase the visibility of the rider
DIY Hacks and How Tos 7 years ago
Nice. My wife has been asking me to make one of these for her to wear when riding at night. Thanks for the tutorials. It saves me a lot of work to not have to start from scratch.
