Internet Controlled Power Outlet
3,984
110
Introduction: Internet Controlled Power Outlet
In this instructable, I will show you how to make an internet connected powerbar.
*Warning:* This instructable deals with high voltage, I will not be held responsible for any potential injuries. Only do this project if you know what you are doing. Furthermore, Do not Plug any appliances that draw more that 5A, even if the relay is rated for 20A.
Step 1: Parts and Tools
Here are the parts and tools needed to make this project:
Parts:
5v relay
NPN transistor (I'm using a 2n2222)
Linkit ONE board with WiFi antenna (included with board)
Wire
1.5k Resistor (Brown Green Red Gold)
Diode
Extension cable
Male headers
Tools:
Soldering iron and solder
Computer with latest version of Arduino IDE and linkit one drivers
Step 2: Wiring
Here is the circuit diagram for the wiring.
You will also have to plug in the WiFi antenna into the uFL connector that says "WiFi/BT ant".
Step 3: Upload Test Code
Here is the test code. Download it, double click to open, then press upload. Open the serial monitor, and copy the first IP address, then paste it into an internet browser. Keep the IP address copied.
Step 4: Upload Final Code
Here is the final code. Double click to open, then press upload.
Step 5: Test...
To test the project, plug the board into your computer, and paste the IP address into a web browser. If it has Three buttons, everything is working. Thanks for viewing this project!
Be the First to Share
    • Stick It Challenge
      Stick It Challenge
    • Origami Speed Challenge
    • Home and Garden Contest
    jaceone
    jaceone
    6 years ago
    Good project. I was with you until I saw the price of the linkit.. yikes..
