Internet on Wheels
Intro: Internet on Wheels
Need Internet on the go? Grab some 22" rims and get online.
If you don't have a pimped out ride or the chicks, this is where this instructable comes in. =)
The concept:
wireless router + wheels - wallplug= myspace everywhere!
Here is the wireless router I used and deconstructed: Wireless Deconstruction
Now this is the result of the reconstruction! But it is not completely finished, I still need to mess with the firmware. As of now the product is jus a physical manifestation of the idea of mobile network.
There is also a similar project, WiFi.Bedouin, worth looking by Julian Bleecher. It utilizes network as art, so without cluttering too much room, here is the link: WiFi.Bedouin
So there are two parts to this.... the wagon that houses all the electronics and the electronics themselves.
I chose wood as the medium for the wagon because it is easier to assemble, compared to, say, aluminium or whatever.
As for the router... any idiot can make it run on a 12 volt battery, but to really utilize it in a way that it can receive and boost wireless internet signals, then you will have to go into the firmware. Right now this is an instructable more about the assembly of the project. If you can make it work, drop some comments!
The concept:
STEP 1: Supplies, Equipment, Ingredients...
There are two sections to the project. First we go into the building of the wagon on wheels that houses the electronics and the other is hooking up the actual electronics.
First the supplies for the wagon I used are:
A piece of plywood (for the platform of the chassis), an axle (wood/copper whatever you can work with), a plank of wood that I used to work with for the miscellaneous parts of the wagon, four lawnmower wheels, some wood screws, and hooks (to anchor the rubberbands).
Some of the tools that made things work:
drill, bits, handsaw, straightedge, measuring tape, and of course a pencil.
The electronics:
12volt battery, inverter, wireless router, and maybe a battery charger
I've got a Netgear WGU624, a 400watt inverter bought from Best Buy, and the 12 volt battery from Fry's
Now on to the wagon making...
Or if u already have a wagon, go on to connecting your router!
The electronics:
STEP 2: Getting the Assembly Parts.... From Scratch
When I took hold of my supplies, I obviously need to hack away wood.
So here it is, using the handsaw cut the needed pieces out of the wood.... the platform, the axle holders, axles, and the sides for the wagon.
The platforms are pretty self explanatory, but here I am cutting out the part where this is needed to hold the axle in place onto the chassis/platform.
And since I dont have a big enough bit to drill a hole that fits the wooden axle, I have to cut several holes and fashion a really rough circle out of a small block of wood.
These pictures are pretty self explanatory... mark your spots, drill, and make holes... and yes this is the best I could do.
STEP 3: All Done With the Parts
Here are the parts all laid out and spray painted.
Took me, a novice woodcutter, hours on end to get this all laid out.
From left to right, top to bottom:
1 chassis platform, 2 side panels, 4 axle holders, 2 front/back panels, and 2 axles.
STEP 4: Putting Together the a Box
Just like as you would do when putting together Ikea chairs or whatnot: drill, screw and everything will come together.
In this step... Connect the axles to the wheels:
Originally I thought I could screw the wheels directly onto the axles. Unfortunately, the diameter of the axles is bigger than the hole of the wheels would allow. So I screw together a plastic cap that came with the wheels onto the axle, and they fit snuggly together.
In my case, because the hole in my axle holders are small, I slid the axle holders onto the axle before I attach both wheels. So two wheels and two axle holders on one axle.
Next for the rear wheels, do everything the same as above, but add the hooks on the axle holders and the wheels in whatever orientation works for the rubberbands.. the powerhouse of the car.
STEP 5: Attaching the Axle Parts to the Chassis
Time to put things together!
Make sure you dont mess this up. It takes mathmatical genius to get this accurate unless you have really good hand eye coordination... which was what I did. Eyeballing works, only if you are good at it.
STEP 6: Panels for the Wagon
Flip the whole thing upside down, and start connecting the panels to the chassis. Why this step? Because your electronics need a little basket to anchor itself as it moves.
STEP 7: It All Comes Together
Now that the wagon is done and moving, here comes the electronics.
Here is the diagram you need to connect your wirelessness:
battery ---> inverter ---> wireless router
For those who are clueless.... 12volt battery can go to a 400 watt inverter (depending on the power needed for the router, bigger the better) which allows the router to plug right in.
Now there are many ways to do this, and I have to admit this is the more expensive route, but it's quick and almost foolproof. If you can solder the wires directly from the battery to the router (getting rid of the middleman) then you don't even need this instructable!!!
Anyways here is my setup as my final product.
20 Comments
wintergoat 13 years ago
AdrianReef 15 years ago
Rimwulf 13 years ago
(i.e. DSL>>>Wireless Router>>>Gateway)
beehard44 13 years ago
Meroki 15 years ago
Callum Snowden 14 years ago
ThinkBeforeYouSpeak 14 years ago
mjnhbg3 14 years ago
serwaa 16 years ago
kidNeutrino 16 years ago
kentback 16 years ago
joejoerowley 16 years ago
tekness 16 years ago
xrobevansx 16 years ago
http://lifehacker.com/software/how-to/turn-your-wifi-router-into-a-repeater-265142.php
rabidpotatochip 16 years ago
computer_gui 16 years ago
GorillazMiko 16 years ago
!Andrew_Modder! 16 years ago
