Active Camera Tripod
Intro: Active Camera Tripod
[ Category: 18+ ]
Digital cameras are wonderful devices making experiments with images very easy.
You might dream of features that are not available in your camera menu.
This project helps you realizing the following:
- cylindrical or hemispherical panoramas
- stop motion animations
- night photography
It can be used “headless ” (no computer attached).
Pictures will be available on camera memory card for computer processing.
This instructable provides drawings and arduino sketch.
The provided sketch (firmware) can easily be upgraded by anyone to provide more features.
You will need the following:
base
- 3x small wheels
- thin panel either wood or acrylic (e.g. plywood, MDF, Medium-density fibreboard)
- 2x standard size servos (e.g. Futaba S3003)
head
- more thin panels
- 1x micro servo (e.g. Futaba S3107)
- “L” brackets (e.g. ~2.5 inches or 6 centimeters)
electronics
- Arduino 2009 (aka. Duemilanove) or latest model
- Arduino Sensor Shield (i.a. grid pin header connections)
- LCD (HD44780-based) + cable + connectors (prefer backlit LCD)
- buttons + prototype PCB + resistors + cable + connector
tools
- laser cutter (for the luckiest)
- drill,
- saw,
- sandpaper,
- pen,
- cutter (for the others)
- soldering iron
other
- bolts and nuts
- threaded rot and wingnuts
- wire
- adhesive tape
- bolt to attach the camera (0.25”)
optional
- buzzer + cable + connector (beep before a shot)
- photoresistor + cable + connector (light -> exposure & lcd back-light)
- night photography
base
- 3x small wheels
head
- more thin panels
electronics
tools
- drill,
- saw,
- sandpaper,
- pen,
- soldering iron
other
- bolts and nuts
- wire
- adhesive tape
optional
STEP 1: Build the Base
Print the drawing without scaling it.
- insert the jpeg-drawings in your favorite editor
- set or keep the image size at 100%
- set your printer driver’s scaling option to “None”
- check the printed scale with a ruler (inches or centimeters)
(adjust and reprint if necessary)
Use a cutter to have adequate marks
Stick the paper on the wood panel with adhesive tape
see picture
Draw more marks
see picture
Saw and drill
see picture
Draw more marks
see picture
Saw and drill
STEP 2: Cut the Sides
Same procedure...
STEP 3: Build the Head
Same procedure...
Drill holes (1/4” or 6.5mm) on the lower panel to fit your cameras.
Attach the panel with threaded rot and nuts/wingnuts
STEP 4: Assemble the Mechanical Parts
STEP 5: Add the Electronics
Attach
the servos,
the Arduino 2009,
the LCD, etc.
Add the "Sensor shield"
the servos,
the Arduino 2009,
the LCD, etc.
STEP 6: The Keypad
We have a simple resistor network for keyboard.
- assemble resistors and buttons
- solder buttons
- put 4.7kΩ close to the VCC (+5V) wire
- put 1kΩ next to the buttons
- put solder according to the drawing
STEP 7: The Display
Power connector (2 connectors)
- VCC (red) -> pin 2 (LCD)
- GND (black) -> pin 1 (LCD)
control connector (9 or 4+2 connectors)
- Data4 (1st) -> pin 14 (LCD)
- Data5 (2nd) -> pin 13 (LCD)
- Data6 (3rd) -> pin 12 (LCD)
- Data7 (4th) -> pin 11 (LCD)
not used
- Enable (6th) -> pin 6 (LCD)
- RS (7th) -> pin 4 (LCD)
On the LCD
- tie pin 1 and 5
- place 4.7k potentiometer between VCC and GND, divider pin on pin 6 (LCD)
not used
On the LCD
- tie pin 1 and 5
STEP 8: Tilt Servo Calibration
Upload the firmware to the Arduino 2009
(power off)
Connect:
- titl servo to digital pin no.5
- LCD as described
- keypad to analog input no. 0
(power on)
Skip the shutter calibration (press the OK key)
and select the "Point to option" on the main menu
Use the up and down arrows until you reach the 90° angle
Adjust the "L" bracket at the horizontal position
(power off)
Connect:
- LCD as described
(power on)
STEP 9: Finalize the Head
Assemble the part from step 3.
Attach the micro servo (the finger on the shutter).
Now, we have something like this...
STEP 10: The Software (sketch)
Find info on http://arduino.cc/en/Guide/HomePage
Use the http://code.google.com/p/arduino/ to compile the attached code.
Plug USB cable and upload.
Setup
- Display welcome message
- Attach the servos one at a time
- Assist user to adjust shutter servo (up and down keys)
Main menu
- "Point to" option will move the camera with the up, down, left, right keys until "OK" is pressed
- "Shoot one" option takes one picture 8-)
- "Cylindrical panorama" option takes a panorama at the defined altitude
- "Hemispherical panorama" option takes pictures on every altitude/azimuth
- "Stop motion" option takes pictures a defined interval
Pressing any key (left/right is better) will send you back to main menu.
Setup
Main menu
STEP 11: The Software (computer)
Stitch with http://en.wikipedia.org/wiki/Hugin_(software) or one of these http://en.wikipedia.org/wiki/Comparison_of_photo_stitching_applications
Animate with http://en.wikipedia.org/wiki/GIMP with GAP (The GIMP Animation Package) or your favorite picture editor.
You will find several instructables for this.
Have fun!
Have fun!
9 Comments
gpirmez 12 years ago
Edouard67 12 years ago
I attach the structure servo with small wire thru the servo arm and the L bracket.
I attach the base servo with small screws.
The servo on the shutter is held by "colson" (plastic clips).
Thx for your interest and sorry for the delay.
FourthDr 13 years ago
I think this would be an excellent opportunity to make an open shield similar to what the Chinese are selling. But with a schematic and eagle cad file included for download. Especially since all the shield seems to do is bring Vcc and GND out to all the Arduino data lines with either headers or some other type secure locking connectors.
I'll post a link here if I get around to designing something similar. In the mean time, think I'll just use a proto shield or bread board.
Edouard67 13 years ago
Yes, it would be nice to have the same shield "open source" if it isn't yet. I really don't know about the licence or available files.
My purpose wih this project was to have fun (and to workaround the soldering as much as possible).
Sure, breadboard or anything similar would be ok.
You might have to patch the sketch (using 3 servos, 1 analog keypad, 1 LCD). Simply locate/update the lines starting with "#define PIN_" to match your choices.
I didn't noticed there were so much shields http://shieldlist.org/
I used the "Sensor Shield V4" search http://www.google.be/images?q=Arduino+sensor+Shield+v4 for this *wonderful* shield; I mean we don't need soldering skills ;-) This is a plug'n'*have*fun* !
I don't find it directly from http://shieldlist.org/
If you can wait, I suggest e*Bay (search "arduino sensor shield").
Check for "#define PIN_SERVO_"... in https://www.instructables.com/id/Intro-Active-Camera-Tripod/step10/The-software-sketch/ for details.
Digital pin 4 --> base servo
Digital pin 5 --> head servo
Digital pin 6 --> servo on the shutter
zazenergy 13 years ago
I haven’t tried a gigapan so far.
As a *quick* patch, I suggest to add an “zoomed panorama” option to the main menu (see function loop()).
Copy the optionMenuPanorama() function, rename it and update the increments in the “for” loops.
Set these increments to smaller values matching your focal length.
The whole process (shooting and stiching) would be slower… But it should work.
