Inverted Fishtail Rainbow Loom Bracelet
91,260
17
7
Introduction: Inverted Fishtail Rainbow Loom Bracelet
Step 1: Supplies
- Loom
- Rubber Bands
- Hook
- C- or S- Clips (not pictured)
Step 2: Set Up Like You Are Making a Normal Fishtail Bracelet
Put a rubber band twisted into an 8 shape and put on two pegs. Then place two more rubber bands on normally, like in the photo.
Step 3: Take the Bottom Band And...
Step 4: Pull It on Top.
Step 5: Do the Same for the Other Side
Step 6: Place Another Rubber Band on Top
Step 7: Instead of Directing Picking Up the Bottom Band, You Pull Back the Middle Band With Your Hook
Step 8: You Then Grab the Bottom Band With Your Hook
Step 9: Then You Pull That Band Over on Top. Repeat on the Other Side.
Step 10: Continue the Same Steps
All you do is just keep adding bands on top then pulling the bottom band through the middle band. That's it! You can gently pull the bottom band like in the picture after you pull each band up and you will start to see the pattern. Continue until your desired length.
Step 11: When You Are Done
When you reach the length you want, don't put any more bands on. You just want the two bands like in the photo.
Step 12: Take the Bottom Bands And...
Step 13: Pull Them on Top of the Other Band
Step 14: You Can Put Your Bracelet on Your Hook Like in the Picture So It Is Easier to Put on Your Clip
Step 15: To Finish, Put the Ends Together With a Clip
Step 16: Enjoy Your Bracelet!
4 People Made This Project!
  • Make It Bridge
    Make It Bridge
  • Big and Small Contest
  • Game Design: Student Design Challenge
7 Comments
_be_back_soon
_be_back_soon
9 years ago
Same I really liked urs and wasn't confusing like the other ones. Good job!
kaylee_rider
kaylee_rider
Reply 2 years ago
Yours, not urs!!!
kawaiilover
kawaiilover
9 years ago
Honestly, I've seen many if these on instructables. But your tutorial is by far one if the best I've seen! Way to go, love em! :)
kaylee_rider
kaylee_rider
Reply 2 years ago
if needs to be of just so you know!!!
kaylee_rider
kaylee_rider
2 years ago
I like the design too!!! It takes some time, but it’s totally worth it once you finish it!!! I hope you keep making tutorials because you do a good job with them!!! Enjoy!!!
Emuharmonu
Emuharmonu
Tip 4 years ago
Give better or more detail in instructions
Leiana2213
Leiana2213
8 years ago
Oooo, Im trying this now cuz I got bored of the fishtail
