Invisible Garage Door Remote
Intro: Invisible Garage Door Remote
One time we left our car parked outside the garage and a thief smashed a window to get to the garage door remote. Then they opened the garage and stole some bikes. So I decided to hide the remote by building it into the car’s ashtray. It works by touching a hidden button under the ashtray's handle. It’s very convenient to find the button by feel instead of looking for the remote control.
STEP 1: Take Out the Ashtray
STEP 2: Open the Remote Control Case
Pry it open with a screwdriver. Remove the guts. Locate the switch that opens the door.
STEP 3: Solder a New Wire Onto Each Contact of the Switch
A small piece of wire with an alligator clip should be soldered to each contact of the main switch.
STEP 4: Drill a Hole in the Ashtray
Drill a hole where you want the button to be. Enlarge the hole with a file until your momentary switch fits and can be operated well.
STEP 5: Hot Glue the Switch in Place
This involves some trial and error to get it positioned right. Start by tacking it in place. Then check the action. When it's good add some more glue to the inside until it is firmly connected.
STEP 6: Connect the Wires
Attach an alligator clip to each of the switch's wires.
STEP 7: Done
Replace the ashtray, 007. You’re good to go.
3 Comments
GranyB 3 years ago
kenbob 3 years ago
Penolopy Bulnick 3 years ago
