Invisible 'floating' Bookshelf
Intro: Invisible 'floating' Bookshelf
After seeing some of the cool invisible bookshelves that people had put on here, I finally got round to doing my own. Here are the results!
STEP 1:
First of all, in a room where space is already at a premium, the logical step is to build up rather than out and make use of space that is otherwise wasted.
STEP 2:
First, I measure the initial pile of books to work out the dimensions and strength of the 2 brackets required. I worked out that the brackets needed to stick out by 6 inches and be around 8 inches tall. I chose a 1 meter length of 5mm thick drawn steel as my brackets as they had excellent strength and wouldn't bent under the weight of the books.
STEP 3:
I then had to bend the steel to 90 degree angles at each end for the brackets. I did this by wedging the steel in an unmovable item and bending it. Requires some strength!
STEP 4:
I then had to drill the holes to mount the brackets to the wall. I did all this before cutting the brackets as drilling a large piece of steel is easier than fiddly small parts.
I then cut the brackets and mounted them to the wall.
STEP 5:
Now comes the tricky part. How to mount the first book without damaging the cover. Well I did have to cut 2 small slits in the cover as shown. The brackets then slide through the slits and under the hard cover of the book.
STEP 6:
Once your largest book is in place, stack the rest up!
11 Comments
Book Girl 8 years ago
randomray 10 years ago
Casavantwilliams 10 years ago
tobychan 10 years ago
Drakekay 11 years ago
fuzzbuzz_600 11 years ago
jessyratfink 12 years ago
tobychan 12 years ago
I see you've done heaps of instructables! Good work!
eligah76 12 years ago
Loopstyle 12 years ago
Thank you!
