IoT APIS V2 - Autonomous IoT-enabled Automated Plant Irrigation System
Intro: IoT APIS V2 - Autonomous IoT-enabled Automated Plant Irrigation System
This project is an evolution of my previous instructable: APIS - Automated Plant Irrigation System
I have been using APIS for almost a year now, and wanted to improve upon the previous design:
- Ability to monitor the plant remotely. This is how this project became IoT-enabled.
- Easy to replace soil humidity probe. I have been through three different designs of the humidity probe, and no matter which material I used, it eroded sooner or later. So the new design was supposed to last as long as possible and be quickly and easily replaced.
- Water level in the bucket. I wanted to be able to tell how much water is still available in the bucket and stop watering when the bucket is empty.
- Better looks. A gray project box was a good start, but I wanted to create something that looked a bit better. You will be the judge if I was able to accomplish that goal...
- Autonomy. I wanted the new system to be autonomous in terms of power and/or availability of the internet.
The resulting project is not less configurable then its predecessor, and has additional useful features.
I also wanted to utilize my newly acquired 3D-printer, so some of the parts will have to be printed.
STEP 1: Hardware
You will need the following components to build IoT APIS v2:
NodeMcu Lua ESP8266 ESP-12E WIFI Development Board - on banggood.com
SODIAL(R) 3-Pin Ultrasonic Sensor Distance Measuring Module, Dual Transducer, Three-pin on Board - on amazon.com
DC 3V-6V 5V Small Submersible Water Pump Aquarium Fish Tank Pump - on ebay.com
- Three color LED - on amazon.com
- Vero board - on amazon.com
- PN2222 transistor - on amazon.com
- Plastic screws, bolts and nuts
- Soldering equipment and supplies
- Wires, resistors, headers and other miscellaneous electronic components
- Empty Tropicana OJ 2.78 QT jar
- 2 galvanized nails
STEP 2: Overall Design
Overall design consists of the following components:
1. Soil humidity probe and plant watering enclosure (combined - 3d printed)
2. Tubing and wiring
3. Tray water leak sensor (3d printed)
4. Control module mounted on top of the OJ jar (placed and enclosed in the 3d printed case)
5. Submersed water pump
6. NodeMCU sketch
7. IoT configuration
8. Power supply: USB via power outlet -OR- solar panel (autonomous mode)
Let's discuss each component individually
STEP 3: Submerged Water Pump
Submerged water pump is located below the handle of the OJ jar (to avoid interference with water level measurement). The pump is placed in such a way that it is "hovering" about 2-3 mm above the bottom of the jar to allow free water flow to the intake.
Because the pump should be fully submerged for normal operation, minimal water level in the jar should be around 3 cm (about 1 inch).
STEP 4: Control Module Mounted on Top of the OJ Jar
I chose standard large Tropicana OJ jar to be a water container. Those are widely available and standard.
The control module is placed on top of the jar after the original tap is removed.
The platform on which control module is located is 3d printed. The STL file is provided in the files and sketches sections of this instructable.
The pump, tubing and wiring is routed through the handle of Tropicana jar to clear up space for water level measurement.
Water level is measured by the ultrasonic distance sensor integrated with the control module platform. Water level is determined as a difference is distance measurement of an empty jar, and jar filled up with water to a certain level.
Control module and US sensor are covered with a 3d printed "dome". STL file of the dome is provided in the files and sketches section of this instructable.
STEP 5: Control Module - Schematics
Schematics for the control module (including the list of components), and bread board design files are provided in the files and sketches section of this instructable.
NOTE: Working with NodeMCU proved to be a challenging task in terms of available GPIO pins. Almost all GPIOs serve a number of functions, which makes them either unavailable for use, or impossible to use in the deep sleep mode (due to special functions they play during the boot process). In the end I managed to find a balance between use of GPIOs and my requirements, but it took a few frustrating iterations.
For instance a number of GPIOs remain "hot" during deep sleep. Connecting LED to those defeated the purpose of power consumption reduction during deep sleep.
STEP 6: Tray Water Leak Sensor
If your pot has an overflow hole at the bottom, then there is a risk of water overflowing the bottom tray and spilling on the floor (shelf or whatever it is your plant is located on).
I noticed that soil humidity measurement is greatly affected by probe position, soil density, distance from the watering outlet, etc. In other words, going by soil humidity only could be damaging to your home if water overflows the bottom tray and spills over.
The overflow sensor is a spacer between the pot and the bottom tray, with two wires wrapped around the bars. When water fills up the tray, the two wires become connected, thus signalling microcontroller that water is present in the bottom tray.
Eventually, water evaporates, and the wires become disconnected.
Bottom tray is 3d printed. The STL file is available from the files and sketches section of this instructable.
STEP 7: Soil Humidity Probe and Watering Enclosure
I designed a hexagon 3d printed enclosure to be a combined soil humidity probe and watering enclosure.
A 3d printing file (STL) is available in the files and sketches section of this instructable.
The enclosure consists of two parts, which have to be glued together. A modified barbed fitting is glued into the side of the enclosure to attach tubing.
Two 4.5mm holes are provided to place the galvanized nails, serving as soil humidity probes. Connectivity to the microcontroller is achieved via metal spacers selected specifically to fit the nails.
3d design is done using www.tinkercad.com which is a great and easy-to-use yet powerful 3d design tool.
NOTE: You might want to ask why I didn't simply use one of the pre-manufactured soil probes? The answer is: the foil on those dissolve within weeks. In fact, even with a limited time the nails are under voltage, they still erode and need to be replaced at least once a year. The above design allows replacing the nails within seconds.
STEP 8: Tubing and Wiring
Water is delivered to the plan via Super-Soft Latex Rubber Semi-Clear Tubing (with 1/4" Inside Diameter and 5/16" Outside Diameter).
The pump outlet requires larger tubing and an adapter: Chemical-Resistant Polypropylene Barbed Fitting, Reducing Straight for 1/4" x 1/8" Tube ID.
Finally, a Chemical-Resistant Polypropylene Barbed Fitting, Straight for 1/8" Tube ID serves as connector to the watering enclosure.
STEP 9: NodeMCU Sketch
NodeMCU sketch implements several features of IoT APIS v2:
- Connects to the existing WiFi network -OR- runs as a WiFi Access Point (depending on the configuration)
- Queries NTP servers to obtain local time
- Implements webserver for plant monitoring, and adjusting of watering and networking parameters
- Measures soil humidity, bottom tray water leaks, water level in the jar, and provides visual indication via 3 color LED
- Implements online and powersave modes of operation
- Saves information about each of the watering runs locally in the internal flash memory
STEP 10: NodeMCU Sketch - WiFi
By default IoT APIS v2 will create a local WiFi access point called "Plant_XXXXXX", where XXXXXX is the serial number of the ESP8266 chip on board of NodeMCU.
You can access built-in webserver via URL: http://plant.io internal DNS server will connect your device to the APIS status page.
From the status page, you can navigate to the watering parameters page and network parameters page, where you can make IoT APIS v2 connect to your WiFi network and start reporting status to the cloud.
IoT APIS support online and power-save modes of operations:
- In the online mode IoT APIS keeps WiFi connection up all the time, so you can check your plant status at any time
- In the power-save mode, IoT APIS checks soil humidity and water level periodically, putting the device into "deep-sleep" mode in between, thus dramatically reducing its power consumption. However, device is not available online all the time, and parameters could only be changed during the time device powers up (currently every 30 minutes, aligned with hour/half-hour real-time clock). Device will stay online for 1 minute each 30 minutes to allow configuration changes, and then will enter deep sleep mode. If user connects to the device, the "up" time is extended to 3 minutes for every connection.
When device is connected to local WiFi network, its IP address is reported to the IoT cloud server, and visible on the mobile monitoring device.
STEP 11: NodeMCU Sketch - NTP
IoT APIS v2 uses NTP protocol to obtain local time from the NIST time servers. Correct time is used to determine if device should enter "night" mode, i.e. avoid running the pump or flashing LED.
Night time is configurable for workdays and weekend morning separately.
STEP 12: NodeMCU Sketch - Local Web Server
IoT APIS v2 implements a local web server for status reporting and configuration changes.
The home page provides information about current humidity and water level, presence of overflow water in the bottom tray, and statistics of the most recent watering run.
Network configuration page (accessible via configure network button) provides ability to connect to local WiFi network, and change between Online and Power Saving modes. (Changes to the network configuration will cause device to reset)
Watering configuration page (accessible via configure water button) provides ability change watering parameters (soil humidity to start/stop watering, duration of the watering run and saturation pause between runs, number of runs, etc.)
Webserver HTML files are located in the data folder of the IoT APIS Arduino IDE sketch. They should be uploaded into NodeMCU flash memory as a SPIFF filesystem using "ESP8266 Sketch Data Upload" tool located here.
STEP 13: NodeMCU Sketch - Local Watering Log and Access to Internal File System
In case network connectivity is not available the IoT APIS v2 system is logging all watering activities locally.
To access the log, connect to the device and navigate to the '/edit' page, then download watering.log file. This file contains the history of all watering runs since logging has been started.
Example of such log file (in tab separated format) is attached to this step.
NOTE: The download page is not available when IoT APIS v2 is running is Access Point mode (due to dependency on online Java Script library).
STEP 14: NodeMCU Sketch - Soil Humidity, Bottom Tray Water Leak, Water Level, 3 Color LED
Soil humidity measurement is based on the same principle as the original APIS. Please refer to that instructable for the details.
Water tray leaks are detected by momentarily applying voltage to the wires located under the pot using internal PULLUP resistors. If resulting PIN state is LOW, then there is water in the tray. PIN state of HIGH indicates that the circuit is "broken", therefore there is no water in the bottom tray.
Water level is determined by measuring distance from the top of the jar to the water surface and comparing it to the distance to the bottom of an empty jar. Please note the use of the 3 pin sensor! Those are more expensive than HC-SR04 four pin sensors. Unfortunately I ran out of GPIOs on NodeMCU and had to cut every wire I could to make the design work on just one NodeMCU without additional circuits.
3 color LED is used to visually indicate APIS state:
- Moderately blinking GREEN - connecting to WiFi network
- Quickly blinking GREEN - querying NTP server
- Brief solid GREEN - connected to WiFi and obtained current time from NTP successfully
- Brief solid WHITE - network initialization finished
- Quickly blinking WHITE - initiating Access Point Mode
- Quickly blinking BLUE - watering
- Moderately Blinking BLUE - saturating
- Briefly solid AMBER followed by briefly solid RED - unable to get time from NTP
- Briefly solid WHITE during access to internal web server
LED does not operate in the "night" mode. NIght mode could only be reliably determined if device was able to obtain local time from the NTP servers at least once (local Real Time Clock will be used until next connection to NTP is established)
Example of the LED function is available on YouTube here.
STEP 15: Solar Power, Power Bank and Autonomous Operation
One of the ideas behind IoT APIS v2 was ability to operate autonomously.
Current design uses a solar power panel and an interim 3600 mAh power bank to achieve that.
- Solar panel is available on amazon.com
- Power bank is also available on amazon.com
Solar panel has built in 2600 mAh battery as well, but it was not able to sustain 24h APIS operation even in the powersave mode (I suspect the battery does not deal well with simultaneous charge and discharge). A combination of two batteries seem to provide adequate power and allow re-charging of both batteries during the day. Solar panel charges power bank, while power bank powers up APIS device.
Please NOTE:
Those components are optional. You can just power the device with any USB adapter which provides 1A current.
STEP 16: IoT Integration - Blynk
One of the goals for the new design was the ability to monitor soil humidity, water level and other parameters remotely.
I chose Blynk (www.blynk.io) as an IoT platform due to its ease of use and appealing visual design.
Since my sketch is based on the TaskScheduler cooperative multitasking library, I did not want to use Blynk device libraries (they are not enabled for TaskScheduler). Instead, I used Blynk HTTP RESTful API (available here).
Configuring the App is as intuitive as it could be. Please follow the attached screenshots.
STEP 17: Sketches and Files
IoT APIS v2 sketch is located on the github here: Sketch
A few libraries used by the sketch are located here:
- TaskScheduler - cooperative multitasking library for Arduino and esp8266
- AvgFilter - integer implementation of the Average filter for sensor data smoothing
- RTCLib - implementation of the hardware and software Real Time Clock (modified by me)
- Time - Modifications for the Time library
- Timezone - library supporting time zone calculations
NOTE:
Datasheets, pin documentation, and 3D files are located in the "files" sub-folder of the main sketch.
HTML files for the built-in webserver should be uploaded to the NODE MCU flash memory using arduino-esp8266fs-plugin (which creates a filesystem file from the "data" sub-folder of the main sketch folder and uploads it into flash memory)
19 Comments
Gianfry60 1 year ago
Can someone help me?
Thank you
Gianfranco
ets Jan 8 2013,rst cause:2, boot mode:(3,2)
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v0005b730
~ld
71: loadParameters.
Erased config set AutoConnect to false
201: getTime.
IoT Plant Watering System
_TEST_ or _DEBUG_ - lights out
TEST MODE
Current local time: 2016-12-21 6:46:7
Current humidity : 59%
Current water level: 200 mm
Status: idle.
7204: cfgInit.
WiFi parameters:
SSID: XXXXXXXX
PWD : XXXXXXXX
AP parameters:
SSID: Plant_11897019
PWD : changeme!
9287: cfgChkConnect.
11287: cfgChkConnect.
Connected to AP. Local ip: 192.168.101.31
13287: cfgChkNTP.
13287: doNtpUpdateInit.
connectedToAP=1
timeServerIP = 132.163.97.6
13329: sendNTPpacket.
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (0):
epc1=0x40207332 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffd90 end: 3fffffc0 offset: 0190
3fffff20: 00000030 3ffef05c 3ffef078 40207332
3fffff30: 40219624 0661a384 3ffef97c 4020d7dc
3fffff40: 00000000 3ffef0a8 3ffef97c 402073ac
3fffff50: 00000000 3ffef700 3ffef97c 402076e2
3fffff60: 00000000 3ffef788 00000001 40202532
3fffff70: 3ffef6bc 00000000 3ffef97c 402082b8
3fffff80: 00000000 00000000 00000001 3ffefaf0
3fffff90: 3fffdad0 00000000 3ffefadc 40203a40
3fffffa0: 3fffdad0 00000000 3ffefadc 4020f464
3fffffb0: feefeffe feefeffe 3ffe8640 40100d1d
<<<stack<<<
⸮@1Q|⸮⸮5⸮⸮КvXI⸮⸮.⸮Ѫ!YKa ⸮⸮*⸮T⸮⸮1))DP⸮*⸮⸮*⸮⸮⸮nzAn )⸮~1⸮Z!yq⸮RtY@sA.⸮⸮⸮*⸮⸮|9!)⸮~⸮⸮ ⸮⸮~1⸮P⸮V⸮⸮⸮305: loadParameters.
Read TTimeStored structure from RTC memory
Magic number:3022033454
ttime number:3770952584
has NTP :188
rtc_comp :-1532729586
310: getTime.
TEST MODE
Status: idle.
7317: cfgInit.
WiFi parameters:
SSID: Area Wifi
PWD : Birillo2012
AP parameters:
PWD : changeme!
9340: cfgChkConnect.
11340: cfgChkConnect.
13340: cfgChkNTP.
13340: doNtpUpdateInit.
connectedToAP=1
13360: sendNTPpacket.
Exception (0):
>>>stack>>>
ctx: cont
<<<stack<<<
⸮@qQ⸮|⸮⸮⸮⸮⸮PvXY%⸮.⸮Ѫ!I⸮ ⸮*⸮T⸮⸮1⸮⸮⸮E*⸮⸮*⸮⸮⸮⸮nzA⸮ )⸮~1rZ!⸮q1RtQ@#A.⸮⸮*9⸮|⸮⸮)⸮~⸮⸮ 8⸮~1 /⸮⸮W4⸮Q⸮⸮70: loadParameters.
has NTP :188
74: getTime.
MikazukiA1 4 years ago
arkhipenko 4 years ago
Rushi008 6 years ago
how to delete old password and ssid in eeprom
arkhipenko 6 years ago
Not sure which scenario you are referring to: AP or Connected to home Wifi?
Assuming AP and assuming you do not remember the old one (other use cases are trivial: just change them on the network configuration webpage) you will have to write a separate sketch that changes the password directly. Alternatively you can change (increment) the numeric value in EEPROM token, which will cause all settings to go back to defaults.
(https://github.com/arkhipenko/IoT_apis2/blob/master/IoT_apis2.ino#L228)
And this is where is happens:
https://github.com/arkhipenko/IoT_apis2/blob/master/IoT_apis2.ino#L751
TeguhA4 6 years ago
Hi,
It nice project, i like it.
Btw, i come here when i googling about esp8266 irrigation.
I have sugesstion, in step 13, you write:
"NOTE: The download page is not available when IoT APIS
Script library)."
Did you know, if you can put js (java script) file on SPIFFS.
Take a look this project : https://github.com/n0bel/ESPrinkler2
You need to download
https://cdnjs.cloudflare.com/ajax/libs/ace/1.1.9/a...
then edit file edit.htm, change script src=/ace.js
take a look this file
https://github.com/n0bel/ESPrinkler2/blob/master/d...
I hope this will improve your project.
TeguhA4 6 years ago
Your welcome.
^_^
KamilW17 6 years ago
Hi,
In the 97th line of sketch there is an include of Timezone.h library. Could you tell how can I obtain this library?
https://github.com/JChristensen/Timezone
ClemS5 7 years ago
Hit there !
Very nice project, congratulations !
I am very interested in reproducing your system but it seems that the IoT_APIS_WiFi libray is absent in the github.
Is it possible to add it ?
Many thanks in advance
arkhipenko 7 years ago
it is not really a "library", it is a way to protect details of my personal wifi network id/password and Blynk IoT keys from being published on GitHub...
This is what you need to do:
in your Arduino "libraries" folder create a subfolder called "MySettings".
Place the following text file there and populate it with specifics of your network, IoT keys, etc.
#ifdef _DEBUG_ || _TEST_
const char blynk_auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
const char* blynk_host = "blynk-cloud.com";
unsigned int blynk_port = 8080; // to test error handdling
const char *CSsid = "your wifi id";
const char *CPwd = "your wifi password";
#else
#endif
and save it as "IoT_APIS_WiFi.h"
restart Arduino IDE and voila! it should work.
Hope this helps.
ClemS5 7 years ago
Sure this helps a lot !
Many thanks for your time.
You also may want to use a more powerful pump. THe one I used can barely pump water up the tube in the setup depicted on the photographs. I had to locate the bucket at the same level as the flower pot for that reason. In that case, please take care with the water level - the level in the bucket cannot be higher than the watering outlet around the plant (so my MAX line was moved lower as a result)
ClemS5 7 years ago
Sure ! Exactly !
Maybe it exists more powerful pumps with 5V voltage.
I planed to use a 12V DC submersible pump (as I already have one) controlled with a half-H driver (L293). With a 12V-5V power regulator the power consumption will be higher but this might do the job.
mjrovai 7 years ago
clever design and a great project! Congratulations! I should use some of your cool ideas on my ArduFarmBot! ;-)
