(IoT) Intertnet of Things With Ubidots (ESP8266+LM35)
Intro: (IoT) Intertnet of Things With Ubidots (ESP8266+LM35)
Today we are going to learn to use the Ubidots platform to visualize data over the internet in a friendly way.
STEP 1: Materials and Assembly:
1-Protoboard.
2-NodeMCU (ESP8266)
3-LM35 temperature sensor.
4-Some wire
STEP 2: Arduino IDE Setting Up to NodeMCU:
Link to be pasted in preferences boards URL:
http://arduino.esp8266.com/stable/package_esp8266c...
-Download the ESP8266 shields package in the boards manager.
-Select your board (NodeMCU).
-And that's it.
STEP 3: Code Credentials Fill and Ubidots Account:
Go to https://ubidots.com/ , sign up, and search for your "default token" and paste it in the code, next to your Wi-Fi credentials.
Library and code here:
-Upload the code to the NodeMCU and verify that it got connected and says OK.
STEP 4: Ubidots Config and Visualization:
1-Automatically a device called ESP8266 will appear on your Ubidots devices after uploading the code.
2-It will has a variable showing the lecture of the sensor in a range of 0-255.
3-We need to create a synthetic variable in function of the first one. To converte the 0-255 value into a Temperature (C) value we most use a function. ((value)*(3.3)*(100))/1024 = centigrade degrees.
4-We create a table in the data field, with a thermometer widget, typing the name of the variable (API LABEL), in this case is called "temp" and click ok.
5-And finally we are able to visualize the temperature of the sensor over the web, wherever we are, could be by the smartphone app and on.
M4k4k0 4 years ago
Soy un aficionado que está experimentando con Iot, intenté hacer este experimento, pero equivoqué el modelo al comprar la placa y no puedo determinar cual de los pines de esta placa corresponde a la "Entrada Analógica" (A0) que usas para leer la señal del sensor de temperatura (Sé que "GND" es Tierra y "V5" corresponde a "VV").
¿me puedes dar una mano indicando cual sería el equivalente en mi placa? o si tienes algún enlace en donde pueda leer y aprender que hace cada pin de esta placa, me sería de mucha utilidad.
¿crees que la pueda usar esta placa para replicar tu experimento?
Saludos
Dangelo
