IoT LED Cheering Stick
Intro: IoT LED Cheering Stick
This instructables show how to use ESP8266 to make a mobile configurable IoT LED cheering stick.
STEP 1: Preparation
Any LED cheering stick that can put LED strip in should be ok, I have an old cheering stick bought 10 years ago when I go to concert
ESP BoardESP-07 or ESP-12(E) should be ok, ESP-12E can simply flash NodeMCU WebIDE full image (can be more lazy)
LED StripNeoPixel, WS2812 or SK6812 should be ok, I have a 144 uint / meter SK6812 in hand, I only need 28 unit to fit in my cheering stick
Mercury SwitchFor detecting cheering stick waving motion
Ressitors3 x 10 k Ohms resistors
Other toolsscrew driver, soldering iron, USB serial cable...
STEP 2: Flash NodeMCU WebIDE
Please follow my previous instructables to flash the latest NodeMCU WebIDE, it is already included the LED stick sample code.
Ref.:
STEP 3: De-Assembly Cheering Stick
Use screw driver de-assembly the cheering stick, remove the blinking circuit board, LEDs and color plate.
This cheering stick have 2 switches and a 3 AAA batteries battery holder, it can be reuse in this project.
STEP 4: Soldering Work
Here is the connection summary:
ESP Board
GPIO05 -> 10 k Ohm resistor -> Gnd -> Mercury Switch -> Vcc GPIO02 -> LED Strip Data Pin GPIO15 -> 10 k Ohm resistor -> Gnd Gnd -> Battery Holder Negative Pin EN -> 10 k Ohm resistor -> Vcc Vcc -> Power Switch -> Battery Holder positive Pin
LED Strip
Vcc -> LED Switch -> Battery Holder Positive Pin Data -> ESP GPIO02 And -> Battery Holder Negative Pin
STEP 5: Re-Assembly Cheering Stick
Squeeze all components in the cheering stick and use screw driver re-assembly it. If you found the LED strip cannot stay straight, you may use card board, wood stick or PET plate stick to the LED strip back for supporting.
STEP 6: Design Display Message
- Use your mobile connect to the ESP board. (if you direct connected to the ESP WiFi SoftAP, browse to http://192.168.4.1/ or if you already configured the ESP and your mobile connected to same AP, try browse to http://nodemcu-webide.local./)
- Select led-stick.html
- Press preview button (the eye button)
- Type the text you want to display, if you are using iPhone or iPad, you can type emoji too
- Press set button
- ESP is very limited in resource for receiving large image data, please be patient to wait for sending the message image data
STEP 7: Happy Cheering & Light Painting!
Its time play it at night!
If you are going concert, you may type the message in your mobile and show it by waving the cheering stick.
You may also use it for light painting, the above sample photos are take by S mode with 1 to 2 seconds shutter speed.
P.S. If you have already saved the image but powered off the stick, you may start the led-stick program by power on the stick and browse to http://192.168.4.1/les-stick.lc?
STEP 8: Customizable Factors
It means the displaying image height, it can be configured at:
led-stick.html line 10
... height="28" ...
led-stick.html line 15
var h = 28;
led-stick.lua line 2
local pin, w, h, offset = 1, 140, 28, 0Displaying image width
... width="140" ...
led-stick.html line 14
var w = 140;
local pin, w, h, offset = 1, 140, 28, 0Auto start at power on
init.lua last line (uncomment)
dofile('led-stick.lc')()
NodeMCU WebIDE
You may refer my previous instructables step 7 for further NodeMCU WebIDE configuration
10 Comments
mtongnz 7 years ago
Do you have a link to the code you're running? I use Arduino IDE, not lua. I'd love to see how your code works and port it to Android IDE.
Thanks
陳亮 7 years ago
abachmann 6 years ago
Hello Sir!
I'm very excited about a cheering stick, i got Dotstars and Neopixels and a NodeMcu, almost everything phisical, to get sarted. But I don't really understand, what code to upload with arduinoIDE to my NodeMcu, to start playing. Can You help me PLZ?
陳亮 6 years ago
Thank You. I will. :-)
DmitriyK10 7 years ago
If to Add more Columns of LED then you can down speed of mooving with equals visual effect ))
陳亮 7 years ago
Is It looks like that just on camera or in real it looks like both?
Wery Nice project! ))
陳亮 7 years ago
RANDOM KNOWLEDGE 7 years ago
i wil make this also,
vote
