IoT Push Notification Using Nodemcu on Phone(For Anything)
Intro: IoT Push Notification Using Nodemcu on Phone(For Anything)
Sending notification for messages, emails are old fashioned...
So lets make something new that is very easy and simpleNO COMPLICATED SERVER SIDE PHP HOSTING OR OTHER COMPLICATION...
Home automation, water pump level, garden watering, automated pet feeding, PIR alarm and much more whatever you want to get notified on your phones.(android/iOS)
ENJOY and be lazy but get notified!!!!!
STEP 1: Components Required
the main component is Nodemcu(ESP8266) or any other equivalent development boards like adafruit huzzah, wemos d1 mini etc.
And the sensors to use depends upon your need...
I'm using the notifier to notify my previously made internet/cloud controlled project, PIR alarm circuit, ultrasonic sensor controlled water level, IR sensor door!!
After the configuration of sensors the vital thing left is programming.
To configure nodemcu in arduino please visit my previous instructables...
NOTE: Please read the whole instructable don't half read it and damage your kits, I will not be responsible :P
STEP 2: ESP_Notify and Library
We can find the ESP notify application on google play store or we can get the apk from anywhere esle.
After installing the app we need to
- SIGN IN(using google account)
- press the SEND TOKENs option
- use your email
- in email you will get the USER ID, DEVICE ID and Library zip URL
- download the zip from the link
Once the library is downloaded you can add it to your Arduino IDE by
- clicking on Sketch
- Include Library
- Add .ZIP Library in the IDE and then selecting the downloaded ESP_Notify-master.zip file from your Download folder.
STEP 3: CODING
To know something about the library go for the examples in arduino:
- File
- Examples
- ESP_Notify
- send_notification.
To make it work just do change 3 things your WiFi SSID (name), WiFi password and Device_Id.
Device_Id you can get from the email forwarded previous by SEND TOKENS.
So after testing the code we can now tweak it for our use like previously told...
Home automation, PIR alarm, water level alrm, IR door sensor notification
NOTE:** PLEASE CHECK THAT DEVICE_ID IS PROVIDED RIGHT AND IN PROPER QUOTATION(NO MISALIGNED QUOTATION)**
STEP 4: Circuit Wise Program
I have used PIR sensor, Ultrasonic sensor, IR sensor for different works as well as in cloud controlled project I have inserted the library and used the "notifier.sendNotification(device_id,"header","message")" in desired places to get notified on my phone on actions.
According to my code I have used pin D0,D1 for Ultrasonic sensor, D2 for PIR, and D3 for IR sensor.
So download the above given code and modify it like you want.
STEP 5: ESP Notify App
From the app we are getting the desired notification and its the simplest app I have found for notification with ESP8266. It's not the best but the simplest.
Pros- very easy, simple, reliable
Cons- couldn't find if parameters can be passed till now, may be added afterwards..
Thanks for the application and the easy to use procedure without going in a hectic process of app, event, php on server creation.
So enjoy and support...
25 Comments
proitasonic 2 years ago
Great!
I'm developing a project in which several esp8266 devices on different internet networks send notification to an android app.
I need to identify which esp8266 device is sending to the android app.
Can you help me?
Thank you very much!
sreenivasulureddy.k19 3 years ago
#include <ESP8266WiFi.h>
#include <ESP_Notify.h>
// input your values here
#define WIFI_SSID "OnePlus 7"
#define WIFI_PASSWORD "68426842"
#define DEVICE_ID "fPC_87i2QSM:APA91bHudb1b6BgW4MH2brJcGpC3Q-xp-s3IoYUlrXJnU_ghHV5uTRbGCqk2lGyG94At6rjG2LevA4QjclfUzz9Yf5pec8AXpaokFUGDLOevdqWAukKhF3x9VfWOhXlSTgkbe_7AzFKj"
// define a notifier
ESP_Notify notifier;
void setup() {
Serial.begin(115200);
// connect to wifi.
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("\n\nconnecting");
while (WiFi.status() != WL_CONNECTED) {
Serial.print(".");
delay(500);
Serial.print("\nconnected: ");
Serial.println(WiFi.localIP());
// Send notification
notifier.sendNotification(DEVICE_ID, "Hello World!", "Stuff, Stuff!");
void loop() {
//empty loop
But i am getting the error like this
<HTML>
<HEAD>
<TITLE>Forbidden</TITLE>
</HEAD>
<BODY BGCOLOR="#FFFFFF" TEXT="#000000">
<H1>Forbidden</H1>
<H2>Error 403</H2>
</BODY>
</HTML>
I am getting no notifications
Please help me sir to solve this ASAP
anammalik838 4 years ago
"23:58:12.613 -> <HTML>
23:58:12.613 -> <HEAD>
23:58:12.660 -> <TITLE>Forbidden</TITLE>
23:58:12.660 -> </HEAD>
23:58:12.660 -> <BODY BGCOLOR="#FFFFFF" TEXT="#000000">
23:58:12.707 -> <H1>Forbidden</H1>
23:58:12.754 -> <H2>Error 403</H2>
23:58:12.754 -> </BODY>
23:58:12.754 -> </HTML>"
wil you please advice me how i can solve this error
kedarm5 5 years ago
Abhrodeep Chanda 5 years ago
NirmalK31 5 years ago
Thanks for early reply. Sir how can receive same alert message from the same ESP to multiple mobile nos with same token.Is it possible?
Thanks Sir, really very good and easy project.But why"invalid library found"was showing after compiling the code,although it is working fine. Can it work at my office?if ESP is at home.
LuLusWorld 5 years ago
I'm only able to use guest WiFi so there is no password. Would it work if I just deleted the code asking for the WiFi password?
cfieiras 5 years ago
How it works with ios? Thanks!
alcanceweb 6 years ago
It worked as a charm. Thank you very much!!
Abhrodeep Chanda 6 years ago
well done. Thanks for trying!!
D6equj5 6 years ago
Sorry but I don't have a clue for that discrepancy of the app. This doesn't happen usually try another gmail account!! that may help :)
gada888 6 years ago
Nice project,but cannot get the app.
Fugit185 6 years ago
I found the app easily, as normal app
very pleased to know that... please notify me if you tried this project!! :)
DavidMyName 6 years ago
One question. The Ultrasonic (HC-SR04) has 5V logic on the Trig and or Sensor output. The NodeMCU has a 3V3 logic on the input. Official the NodeMCU is not 5V (input) tolerant. You don't have any trouble? I did a project with NodeMCU and Ultrasonic and I us some resistors the level shift 5V to 3V3. I guess for long term operation it is better.
