Introduction: IoT Smart Clock Dot Matrix Use Wemos ESP8266 - ESP Matrix
Make your own IoT Smart Clock that can:
- Display Clock with a beautiful animation icon
- Display Reminder-1 to Reminder-5
- Display Calendar
- Display Muslim Prayer times
- Display Weather information
- Display News
- Display Advice
- Display Bitcoin rate
- Display Instructables Followers & Views counter
- Display Twitter follower counter
- Display Facebook Page like counter
- Display Instagram follower counter
- Display Youtube Subscribers (realtime) & Views counter
Easy to build just need a Wemos D1 Mini and MAX7219 LED Dot Matrix Panel. No need programming skill no need Laptop/PC to program Wemos ESP8266 microcontroller, just need Android phone to upload sketch/firmware to Wemos via USB OTG.
It runs completely autonomously and be configured and controlled via an Android app, with the app you can configure and setting IoT Smart Clock (ESPMatrix) device very easy with a simple interface.
Step 1: Things Needed
Here are the things that you will need to make ESP Matrix:
- Wemos D1 Mini - ESP8266
- MAX7219 LED Dot Matrix Panel
- Dupont cable - Included in LED Dot Matrix Panel
- OTG Adapter
- Micro USB cable
- 3D Printed Case
- Pieces of transparent colored Acrylic 129x32x3mm
- Android phone (Installed ESP Matrix app)
Step 2: Modify Pin
1) Remove the LED Dot matrix component in the first column that have the soldered header pin on pcb.
2) Twisted all male pin headers 180° using long-nose pliers, so that they point inward.
Step 3: Wiring
1) Cut half of the existing dupont cable, so it becomes around 10cm.
2) Connect female header on dupont cable with male header on LED Dot matrix panel, see picture.
3) Separate the cable into two parts, 2 cables for VCC & GND, 3 cables for CLK DS & DIN. then enter into the hole on the pcb, see picture.
Step 4: Before Soldering
1) Peel the end of the cable using a wire stripper tools.
2) Then cover all ends of the cable with tin.
Step 5: Soldering
1) Solder to connect CLK to D5, CS to D6 & DIN to D7.
2) Solder to connect VCC to 5V & GND to G.
Step 6: Putting It All Together
You can use double sided tape, to glue between the Wemos and the LED Dot matrix panel, see the picture. Also reinstall the LED Dot matrix component which is in first step removed
Step 7: Placing to the 3D Printed Case
This 3d printed case is design more slim and pressing to make it look solid and robust, so to install it is not so easy need a little pressed.
ESP matrix can be made in two sizes, a short 32x8 pixel of LED use 1 panel LED Dot matrix and a long 64x8 pixels of LED use 2 panel LED dot matrix, so to make a 3D printed case depends on your choice.
Step 8: Add Acrylic
To make the light of the LEDs be more clear and diffused, on the LED surface add black transparent colored acrylic.
There are two sizes of acrylic:
- A short: 129x32x3mm.
- A long: 257x32x3mm
Step 9: Programming
1) To program the Wemos ESP8266 (ESP Matrix) very simple, you only need to connect Wemos (ESP Matrix) to an Android phone via a micro usb cable and OTG adapter, see picture.
2) Then install the ESP Matrix app from Google Playstore. https://goo.gl/b9YAth
3) In the first welcome screen tap UPLOAD button.
Step 10: App Interface for Configuration
After programming is complete then it is necessary to set some parameters of the devices:
1) Connect ESP Matrix device to network internet using app.
2) You need Sign-up to get an API key from openweathermap.org, then copy the your API key to the weather option in app.
3) You need City ID from openweathermap.org, eg.2643743 for London, then copy the your City ID to the weather option in app.
Step 11: Make a Long Type 64x8
If you feel dissatisfied with the short type because you can only see short messages, so you can make the long type the length of the size two times longer. For more details you can follow the tutorial in this video.
Step 12: Enjoy
Hopefully you enjoy your ESP Matrix. If you do, please share your makes, share the link, like and subscribe. As always, if you have any questions please let me know!
50 Comments
Question 6 weeks ago
HOLA buenas mi cosnsulta es que conecto todo Wemos ESP8266 (ESP Matrix) la matriz led le cable y el otg al cel y me dice que no esta coentado al ucb y si lo conecto directamente a una fuente si enciende cambio de nuevo y lo mismo ya he bajado varias apps de matrix y me dice lo mismo ¿ que recomendacion me dan
me falta probarlo de distinta forma todo sobre la proto boar y ver que pasa?
cual puede ser la pocible solucion
Answer 25 days ago
Tengo ese mismo problema con el conector tipo C se enciende la Matrix y me dice USB no conectado
Alguien puede darnos la solucion
5 months ago
Hello
Congratulations for this project
I would like to have your advice, I have a 24h display bug when it displays only from 10am to 11am (see photo)
Can you help me solve the problem
Best regards
1 year ago
I have this running for over two years with no problems, using the pro version of the app. Then two days ago the news api says error chech your api key is correct, (it is) but what I have noticed is News.org where the key come from are say they do not provide service io UK servers, I have tried loads different things from News setteigs but still no luck, anyone have an idea of how to resolve this, I have contacted developer of app but haven't replied as of yet, I think these are awesome so I just have to sort it out, any help would be grateful. thx
1 year ago
- I use ipscanner to find wemos ip addres. because the name on the matrix display is not the same as the name on the network.
- When setting the time offset, a notification appears that the "temperature offset" has been successfully changed not the time offset. and the time display does not change.
- Problem with calendar, 1 day late maybe due to offset setting failure.
sorry for my english (google translate)。
よろしくね。
Question 4 years ago on Step 10
hi, i follow all the instructions but i stuck on the app says that "connection error" scroll down to refresh , i write the ip address on the sync to esp but same thing, the app no connection error. i am using android 7 samsung j7 prime. i also able to connect to my mifi network. after that i use the app interface still no connection errror. gelp me please ..tnx
Answer 1 year ago
I am having the same problem dude, everything seems to work fine with the ESP8266 connected to wifi and when you try to change some menus you get always the same sentence: Connection error, scroll down to refresh! Not sure if the problem is from the app or the Android version.
1 year ago
Hello,
Thank you for the awesome project.
I finished the whole project, everything connected, and the LEDs are working fine but the application "ESP Matrix" keeps giving me this message " Connection error, scroll down to refresh" I tried to refresh a lot of times but still nothing. The same error each time I try to change the time, city, or anything else. The whole menu is closed, the city is stuck on London with the whole origin setup.
Question 2 years ago
Hi~
When uploading from the app esp matrix, an error at 3~4%
How can I slove the error?
thanks!
Answer 2 years ago
Hi... I just started building my kit but also get an error while uploading... stops at 6% everytime... did you manage to fix yours?
2 years ago on Step 11
i cant see esp wifi....
2 years ago
My Smart Clock is restarting constantly.(every ~45seconds )
I don't know what the problem is. I have already used two distinct power supplies.
Issue:
The instagram counter doesn't works.
Suggestions:
Add twitch counter
Add Multilingual-Date
Add other Crypto currencies
2 years ago
requests go to api, but data on device screen is not present, what should I do?
2 years ago
At the moment, it does not show the number of YouTube subscribers, api, id entered correctly. When is the firmware update?
2 years ago on Step 5
How can i change ss/cs pin to D10
4 years ago
Mmmm, very cool, like a DIY simple LaMetric. Looks great, but went all the way down the post waiting to see how you coded the ESP8266, how the OTG worked, the code for driving the display etc? Nothing?
Reply 2 years ago
It can be possible
Reply 4 years ago
what do you mean by this, am about to order parts for the project and want to make sure it is duable
Reply 4 years ago
This is a "closed" project, there's no code available and you would have to use their Mobile App to install and configure. Like @MikeL90 said below - this is probably using open source software and frameworks, but they are not releasing the code. You will be able to make it and use it, but it's not very in keeping with open source and the maker community...
Bonjour ,
Pourquoi je n'arrive pas a me connecté au montage en wifi ?(non détecté) merci de votre réponse et éventuellement d'une solution )
Hello ,
In addition to this, you need to know more about it.
Why can't I connect to the wifi assembly? (Not detected) thank you for your answer and possibly a solution)
