Introduction: Irish Soda Bread (adjusted From Simply Recipes)
Soda Bread isn't JUST for St. Patrick's Day. It pairs really well with stews, steaks, and sometimes we use it for sandwich bread for corned beef! I prefer my soda bread dough to be a bit on the “wet” side, so I'll add a few more tablespoons of buttermilk.
Step 1: Ingredients
- Ingredients
- 4 to 4 1/2 cups flour
- 1 3/4 cups buttermilk (No buttermilk, no problem. For every 1 cup of milk, add 1 tsp of vinegar and let it sit for 10 minutes or so)
- 1 large egg, lightly beaten
- 4 Tbsp. butter
- 1 teaspoon baking soda
- 1 teaspoon salt
- 1 Tbsp. sugar
- Optional 1 cup currants or raisins (we did not use them)
Step 2: Whisk Together
Whisk together flour, sugar, salt, baking soda: Preheat oven to 425°. Whisk together 4 cups of flour, the sugar, salt, and baking soda into a large mixing bowl.
Step 3: Add the Butter
Work the butter into the flour, add currants or raisins: Using your (clean) fingers Or a Pastry blender, work the butter into the flour mixture until it resembles coarse meal, Optional (then add in the currants or raisins).
Step 4: Add the Wet
Make a well, add buttermilk, egg, knead into dough: Make a well in the center of the flour mixture. Add beaten egg and buttermilk to well and mix in with a wooden spoon or spatula until dough is too stiff to stir.
Dust hands with a little flour, then gently knead dough in the bowl just long enough to form a rough ball. If the dough is too sticky to work with, add in a little more flour. Do not over-knead!
Step 5: Mixing
Transfer dough to a lightly floured surface and shape into a round loaf. Note that the dough will be a little sticky, and quite shaggy (a little like a shortcake biscuit dough).
You want to work it just enough so that the flour is just moistened and the dough just barely comes together. Shaggy is good. If you over-knead, the bread will end up tough.
Step 6: And Now We Bake
Score with an X and bake: Transfer dough to a large, lightly greased (we used just the butter wrapper) cast-iron skillet** or a baking sheet (it will flatten out a bit in the pan or on the baking sheet).
Using a serrated knife, score top of dough about an inch and a half deep in an "X" shape. The purpose of the scoring is to help heat get into the center of the dough while it cooks.
Transfer to oven and bake until bread is golden* and bottom sounds hollow when tapped, about 35-45 minutes. (If you use a cast iron pan, it may take a little longer as it takes longer for the pan to heat up than a baking sheet.) Check for doneness also by inserting a long, thin skewer into the center. If it comes out clean, it's done.
*If the top is getting too dark while baking, tent the bread with some aluminum foil.
**If you use a cast iron skillet to cook the bread in the oven, be very careful when you take the pan out. It's easy to forget that the handle is extremely hot. Cool the handle with an ice cube, or put a pot holder over it.
Step 7: Let Cool a Few Minutes
Let cool a few minutes: Remove pan or sheet from oven, let bread sit in the pan or on the sheet for 5-10 minutes, then remove to a rack to cool briefly. Serve bread warm, at room temperature, or sliced and toasted. Best when eaten warm and just baked.
Hint 1: If the top is getting too dark while baking, tent the bread with some aluminum foil.
Hint 2: If you use a cast iron skillet to cook the bread in the oven, be very careful when you take the pan out. It's easy to forget that the handle is extremely hot. Cool the handle with an ice cube, or put a pot holder over it.
