Ironic Mustache Twitter Interface
Intro: Ironic Mustache Twitter Interface
This interface is really cool but you've probablly never heard of it.
The IMRI seeks to create a twitter experience like no other, and tickle your mustache at the same time. Using space age technology, you too can know the moment someone is talking about staches on the twitterverse. Everytime someone tweets out #mustache, your mustache will vibrate, telling you exactly when someone is talking about mustaches.
Perfect for those hipsters who have everything.
STEP 1: Stuff You Might Need If You're Cool Enough
A fake mustache, or a real one that you ripped off your face
vibrating pager motor
a retro arduino board
sweet programming skills
Old drinking straw
some solid core wire
Not necessary but you're a total poseur with out it:
Wayfarer sunglasses
Fixie bike
a case of PBR brah!
Old drinking straw
Wayfarer sunglasses
Fixie bike
a case of PBR brah!
STEP 2: Putting the 'stach Together
First you gotta make the 'stache vibrate.
Solder some wires to your motor so you can attach it to the arduino easier. I used small solid-core, but this is a free country DO WHATEVER YOU WANT!
PROTIP: use your lighter to strip off the small wires. The plastic will just crumble off. Once your done you can use your lighter to light your american spirit cigarette. What? you're still smoking camels? how lame.
Next i took a drinking straw and put it around the motor, i did this because the stache' hairs get caught in the motor otherwise.
Lastly i took some hot glue and told that motor whos boss, but attaching it to the stache' Celebrate by throwing on some MGMT on that vintage ipod from 2006
STEP 3: Code the 'Duino and Computer.
I could have used ruby, but ruby is for wannabe hipsters who hang out on in North Beach and think Chipotle is a "real" burrito place.
I explained this in more detail in My Twittering coffee pot instructable, check that one out if you're having trouble
Python is mad fresh, Here's the code for that. Just run in a terminal on your Computer:
The arduino code is here, to be uploaded to your arduino:
import twitter import serial import time class Moustache(object): def __init__(self): self.api = twitter.Api(consumer_key='jWa7GzYNHjI2FVocKNgNig', consumer_secret='PUT_HERE', access_token_key='PUT_HERE', access_token_secret='PUT_HERE') self.status = [] self.status2 = [] self.ser = serial.Serial('/dev/ttyUSB0', 19200) def finder(self): twit = self.api.GetSearch(term = '#mustache') print twit self.status = [s.text for s in twit] ##put status in an array print self.status if self.status == self.status2: print 'Awaiting Tweet' self.ser.write('0') else: print 'Mustache Found' self.status2 = self.status self.ser.write('1') if __name__ == "__main__": print 'Welcome To Mustache Finder!' m = Moustache() while 1: m.finder() time.sleep(5)The Python using the Python-Twitter Library searches recent tweets with #mustache and then gives a signal to serial to interact with the arduino. While this code is running your arduino along with mustache module should be connected.
int relayPin = 13; // LED connected to digital pin 13 int incomingByte = 0; //declare incoming byte // The setup() method runs once, when the sketch starts void setup() { // initialize the digital pin as an output: pinMode(relayPin, OUTPUT); Serial.begin(19200); // set up Serial library at 19200 bps Serial.println("Arduino is ready!"); } // the loop() method runs over and over again, // as long as the Arduino has power void loop() { if (Serial.available() > 0) { // read the incoming byte: incomingByte = Serial.read(); Serial.println(incomingByte); if (incomingByte == 49){ digitalWrite(relayPin, HIGH); } else { digitalWrite(relayPin, LOW); } // say what you got: Serial.print("I received: "); Serial.println(incomingByte, DEC); } } </pre>Once all that is done, you should feel the tweets pour in.
STEP 4: Hooking It Up
Wire it all together, run the code on your computer and arduino and you're done.
You now have the dankest vibrating mustache in the land, and you can know exactly when someone it talking about a 'stache on the twitterverse.
Hope you had fun, i'm out, i gotta alleycat dive bar race to go to.
20 Comments
dasmalle 9 years ago
OKay I have to admit your project is super cool, I will try to connect it to our dinosaur twitter game!
https://www.facebook.com/TweetLovers
Hustleer 11 years ago
Traceback (most recent call last):
File "/Users/mcasanas/Desktop/Mous.py", line 6, in
File "/Users/mcasanas/Desktop/Mous.py", line 11, in Moustache
self.ser = serial.Serial('/dev/tty.usbmodemfa131', 19200)
NameError: name 'self' is not defined
caarntedd 12 years ago
Andrew Arace 12 years ago
I had a arduino mod that would send a tweet whenever my home back door opened, so i could get the tweet when i was out - twitter alarm system, no computer required.
woutervddn 12 years ago
TheoTTFF 12 years ago
chicopluma 12 years ago
JBZG 12 years ago
Only if you happen to be Chuck Norris!
What if you spell it MOUSTACHE...will it still work!?
JBZG 12 years ago
neffk 12 years ago
PepperDust 12 years ago
I can see this technology being horribly abused.... ^_^
Wasagi 12 years ago
cfullerton 12 years ago
broach 12 years ago
Here's the site and project description: http://julyna.com/
martzsam 12 years ago
crapflinger 12 years ago
*grumbles under his breath about hipsters ruining awesome mustaches for everyone*
Grimarr 12 years ago
pdxnat 12 years ago
Cabe 12 years ago
Loving the instructable, I only wish my own 'tash would tweet!
