Ironman
Intro: Ironman
Things you'll need:
Laptop
Card stock
Pepakura viewer/designer
5mm plastazote/EVA foam
Knife and a load of blades
Glue gun and glue sticks
Velcro
Buckle clips
White LED's
Sandpaper
Engraver
PVA glue
Primer
Red and gold paint
Clear lacquer
And a shit load of patience :)
Laptop
Card stock
Velcro
Buckle clips
White LED's
Sandpaper
Engraver
PVA glue
Primer
Red and gold paint
Clear lacquer
STEP 1:
Print off pep file on to the card stock and then I cut out the templates from the card stock. I then cut those templates into the plastazote foam one piece at a time, sometimes doing more if possible ( it all depends on curves, depths, angles etc.
STEP 2: The Helmet
When all pieces I foam are cut out, I took my glue gun and started to glue the corresponding together, only gluing one side
STEP 3:
When everything is glued I then covered the foam with PVA glue. A few coats 3 or 4 will do. Waterproof the lot of it
STEP 4:
More to come soon
3 Comments
itri45 10 years ago
genius way to do this. But how did you get the design to build each single peice?
itri45 10 years ago
mvan h1 10 years ago
