Ironman Mark42helmet
4,133
17
Introduction: Ironman Mark42helmet
This helmat is a mark3 template,but i change it to mark42
Here are the steps of making the helmet
Step 1: Print a Template Out
First,print a template out,i use the mark3 template,after cut it out,you should use three A4 size to make it (if you wanted to wear it
Step 2: Make a 3D Model
After you cut the template out ,you must prepare lots of hard cardboard,and make a 3d model with a hot glue gun
Step 3: Add Some More Ditails Parts and Change the Ears of the Helmet
You must figured out the mark3 and the mark42helmet's ears is different,so you must change it
Step 4: Add the Fibre Glass in the Inside of the Helmet
Use the fibre glass to harden the helmet
Step 5: Add the Bondo Glass on the Outside
Harden the helmet and make more nice by adding bondo glass
Step 6: Sand It and Add a Layer of File in the Inside the Helmet
Sand the helmet,add a layer of file inside the helmet,to avoide to hurt your head
Step 7: Your Done!
Congragilation!!!your done!!!^^
Be the First to Share
    • Big and Small Contest
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
