Introduction: JAWS... a Cardboard Costume
This instuctable instructs you on how to make a cardboard costume of a great white shark. This was a school project and it involved working in a group, and each group had to make a line of marine themed costumes.
Design Brief : Develop a line of marine themed costumes made from recycled cardboard that can be slotted together for assembly that adults can easily make for middle school aged children to use indoors or outdoors when under minimal supervision.
My group, chose the theme : Sharks.
Specs and Limits: Single, Double or Tri-Wall recycled cardboard
                                 Flat Pack Costume Design
                                 Easily Constructed by Adults
                                 Common Marine Theme
                                 Few Parts as Possible for ease of Construction
Step 1: Materials and Tools
Materials List:(S1) Cardboard, 60in x 35in, 20in x 15in, 25in x 20in, 15in x 2in
Tools : (T1) Cutting Mat
             (T2) Utility Knife
             (T3) Ruler
             (T4) Pencil
             (T5) Circle Template or Compass
Step 2: Making the Front Piece of the Body
Part P1: Front Piece of Body
1. Draw outline with pencil (T4) on cardboard (S1) with correct measurements ( 50in tall, 32in Fin to Fin. See Font Piece of Body on left side of picture Below .)
2. Measure with ruler (T3) for correct dimensions
3. Place Cutting Mat (T1) down.
4. Use utility knife (T2) to cut out model
5. Cut out head hole with utility knife (T2) ( 15in by 15 in)
6. Put slits in correct places with utility knife (T2) ( Starts where head hole ends on each side. 1 1/2 in for each slit.)
Step 3: Making the Back Piece of the Body
Part P2: Back Piece of Body
1. Draw outline with pencil (T4) on cardboard (S1) ( Measurements: 50in tall, 32in Fin to Fin. See back piece on right side of picture below .)
2. Repeat steps 2,3,4,and 6 from front piece for back piece.
Step 4: Making the Dorsal Fin
Part P3: Dorsal Fin
1. Draw outline of fin on cardboard (S1) with pencil (T4) ( Like a Triangle: 12 x 16 x 16)
2. Place cutting mat (T1) down
3. Cut out fin with utility knife (T2)
4. Put slits in correct places with utility knife (T2) ( 2 inches from 12in base. 2 inch slit.)
Step 5: Making the Caudal Fin
Part P4: Caudal Fin
1. Draw an outline of fin on cardboard (S1) with pencil (T4) ( 18in high, 22 inches across.) Pay attention to picture!
3.Cut out fin with utility knife (T2)
4. Put slits in correct places with utility knife (T2) ( Where the point is, go over 2 in and make a 1 inch slit.)
Step 6: Making the Connectors
Part P5: Connectors
1. Draw an outline on cardboard (S1) with pencil (T4) ( 15in long by 2in wide.)
3. Cut out connector with utility knife (T2)
4. Put slits in correct places with utility knife (T2) ( 1in in make a 1in slit. Do on both sides and repeat on both connectors)
Step 7: Assembly of Costume: Sliding Connectors In
1. Using the slits in the Front Piece (P1) and in the Back Piece (P2) slide the Connectors (P5) in
( See picture)
Step 8: Assembly of Costume: Sliding Dorsal Fin In
1. Using the slits in the Back Piece (P2) slide in the Dorsal Fin (P3)
(See picture)
Step 9: Assembly of Costume: Sliding Caudal Fin In
1. Using the slits in the Back Piece (P2) slide in the Caudal Fin (P4)
(See Picture)
Step 10: Assembly of Costume: Finished Product
1. Slide costume over body so that Connectors (P5) rest on person’s shoulders.
(See Picture for Final Product!)
