JCAII / British Airways - Icelink DTS
Introduction: JCAII / British Airways - Icelink DTS
About: Netquity Corporation
JCAII Icelink DTS rev v2
Lightning Cable Replacement Guide
Step 1: Remove Top Cover
Remove top cover with #1 Philips screwdriver
Cover is held in place with 4 Philips screws
Step 2: Disconnect DTS Harness
Disconnect DTS wiring harness or completely shut down Vestergaard Rig
DTS wiring harness is held in place with two precision slotted screws #1
Step 3: Disconnect USB Lightning Cable
Disconnect USB lightning cable from USB socket
Step 4: Unscrew Cable Gland Interior Nylon Nut
Unscrew cable gland interior nylon nut
Step 5: Lightning Cable and Cable Gland Removed
The lightning cable and cable gland should now be released and can be removed from the DTS enclosure
Step 6: Remove Cable Gland Exterior Nut
Remove cable gland exterior nut
This should allow you to now route the lightning end of the cable out of the cable gland
Reverse process with the replacement Lightning Cable
Be the First to Share
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    • Hand Tools Only Challenge
