Hydraulic Arm From Syringes
Intro: Hydraulic Arm From Syringes
after getting my prize in spring cleaning challenge I'm more enthusiasm.If you are looking for easy to make and techy, this is the right place for you. All the material used is cheap and easily available at pharmacists.
STEP 1: Material Required
Supplies required-
10 ml syringes X 10
pipe (you can use the one used in water filters)
wooden plank
nuts and bolts
nails
angle brackets
hot glue sticks
18mm drill bit
wheels
metal sticks(for wheels)
wooden sticks(for arms)
tools required -
- drill
- glue gun
- hammer
- screw driver
- filer
STEP 2: Holes for Syringes
Drill 5 holes on the smaller wooden plank with 18mm flat drill bit
STEP 3: Fixing Syringes
for fixing syringes use very hot hard glue.paste the glue on the syringe ends
STEP 4: Making the Base Plate
take the 2 pieces and join them with help of angle brackets and secure them with screws
STEP 5: Making the Base for Crane Arm
STEP 6: Making Base Arms of the Crane
first cut the 2pieces of size-27cm. now drill 3 holes at distances of 2cm,12cm,25.5cm respectively from base in each as shown above.add the screws on all the holes as shown
STEP 7: Making the Middle Arm for Crane
first cut the 2pieces of size-27cm . now drill 4 holes at distances of 1.5cm,12cm,23.5cm,26cm respectively from base in each as shown above.
STEP 8: Grabber(hand of the Crane)
for making the grabber you need to kind of thin wood of size 9cmX6cm . now with help of a chisel cut out small squares out of that as shown above.now make them smooth with help of a filer.you need 2 same size pieces and a square block. join them with hot glue as shown in next step
STEP 9: Hydraulics of the Crane
follow the steps as shown in the pictures.for joining the front of syringes i've used hose clamp and hobby clay.i tried other ways but they were useless.
STEP 10: Final Model
hope you like it do not forget to vote :D
More posibilities
wheels can be added
a box for material can be added
17 Comments
ayashaswi 4 years ago
muffin1mister2 7 years ago
I made it!
Where did you get the pipe?
sanyam jain 7 years ago
at a departmental store
you can get it from repair shops that repair water filters
Bongmaster 8 years ago
thats a hydrolic arm, JCB is a brand name ;)
VedantS13 7 years ago
oh u r a smart guy .. @Bongmaster
RyanR128 8 years ago
I made it
I made it
I made it
I made it
AMAN PRATAPS 8 years ago
can i get more pictures plz???
but why you have'nt make a car???
AnkurJ1 8 years ago
stechi 8 years ago
There are five pairs of syringes, but I can only see four pipes. Can you say what action each of the five pairs is doing? I need to know, cos I want to make this!
sanyam jain 8 years ago
yes sure.one is for base arm,one for middle and one for the claw.remaining two are for right and left movement and the one i did not use was for jack(because mine did not have tyres)it would be connected to two 5ml syringes
livichris 8 years ago
BeachsideHank 8 years ago
A short video of your build in manipulative action would no doubt be most impressive.
