Introduction: Jewelry Box With a Screw on Lid.
A round box with a screw on lid. This is my first instructable and I hope people find it useful.
Step 1: Design the Box
I drew a template using a coffee can for the circle. Divided the circle into 4 parts for separate storage in the finished box.take note of the circle in the middle. this will hold the bolt which screws onto the lid.
Step 2: Cutting the Pieces
Using my scroll saw I cut out the circle then the inside sections.
Step 3: Assembly
I made 2 identical pieces and now I'm gluing them together. Clamp well until glue sets.
Step 4: Flower for the Lid
I cutout a flower which will be glued to the lid. It serves a few purposes. It hides the nut, acts like a knob / handle and makes the finished box more attractive.
Step 5: Cutout a Stem
I cutout a stem which makes the flower more finished.
Step 6: Nut Inside the Lid
This is a standard 1/4" nut. I notched out the shape of the nut so it won't turn. There are better style nuts that should be used but this was all I had handy.
Step 7: Bottom Piece
I traced the outside shape onto a 1/8th piece of plywood which will be used for the bottom. Just glue, clamp and let dry.
Step 8: Sanding
Now is the time to finish with your sanding. I screwed the lid on snug then sanded the sides till all pieces were flush and smooth.
Step 9: Painting
I should have painted my flower before gluing it to the lid. would have made painting it a lot quicker.
Step 10: Finishing
I like to use dark stains. This one I chose is called red oak 215 by minwax. After staining and left to dry I apply my first coat of polyurethane. It's fast drying and again made by minwax. After the coat dries I'll give it a very light sanding then another coat of polyurethane. This will be repeated until I get the shine I'm after.
Step 11: Finished Product
Lots of sanding and a few coats of polyurethane and your box should look something like mine.
Again, this is my first instructable so hope it's easy to follow.
Post comments below.
2 Discussions
5 years ago on Introduction
Quite a clever design. I was expecting the wood to be threaded but this is something I've never seen before! I can think of several uses for this design in the shop too.
Reply 5 years ago
Thank you.
