Jug of Plenty- Automatic Filling Water Jug
Intro: Jug of Plenty- Automatic Filling Water Jug
If you're like me, you too are frustrated by having to fill a water bottle or glass to have in the bedroom or office. Well, look no further, because this Instructable describes how you can run a clean water line all around your house with some very basic tools.
What's more, you can easily have a jug full of water which refills every time you use it, making sure
- You have some potable water in emergencies
- The flow rate is high when you pour water out of the jug
I'd like for you to seriously consider the idea of running a water line in your house, it's really no more difficult or intrusive than an ethernet cable. So, let's get to business!
STEP 1: Turn Off the Water Supply
You'll need some place to access the main water line. Probably the easiest place to do this is under the bathroom or kitchen sink. So, first turn off the water valve by rotating in clockwise, so that you can go on to detach the water hose.
STEP 2: Detach the Existing Water Hose
You'll need an adjustable wrench to detach the existing hose. It's also a good idea to place a tray under the valve, to catch any water in the hose.
STEP 3: Add the Water Line Splitter
The water line splitter (also called T splitter) will allow water to flow up to the tap as usual, but also fork a supply line to the 1/4" water line.
STEP 4: Attach a Valve on 1/4" Line
The first thing we connect to the 1/4" line should be a valve so that we can turn off water to the whole 1/4" line if needed. Thankfully, this is very easy with 'push to connect'. Just attach a small section of pipe to the valve by pushing it in and then push connect the other end of the line to the T-splitter.
STEP 5: Attaching the Water Filter(optional)
The water filter can be mounted with the provided screws and mount. The inlet of the filter is connected to the 1/4" valve using a section of 1/4" pipe. Pay special attention to the arrow marking direction of flow on the filter.
STEP 6: Clean the Filter(optional)
The filter contains activated charcoal or carbon black. By letting a few gallons of water wash through the filter, the loose carbon is flushed out. This only needs to be done once with a new filter.
STEP 7: Run the Water Line
Now, you have a clean water supply in 1/4" pipe. You can route it to wherever you need in the house. The pipe can be bent and inserted through walls if needed. I used 6mm cable clips to direct the line along the wall.
While drilling through walls, please use extreme caution to avoid electrical and load bearing walls. When you're not sure if you should be drilling through a wall, assume that you shouldn't!
STEP 8: Jug of Plenty-1
Because we're filtering the water, the water flow rate will reduce significantly. So, it can take several seconds to fill up a glass, which is unacceptable! The jug of plenty solves this problem by providing a local reservoir which can fill a glass in a few seconds.
To start with this, we puncture a hole in the jug lid and attach a threaded valve connector to it.
STEP 9: Jug of Plenty-2
The float switch is connected to bottom of the lid, and a valve is connected to the top as shown in the pictures above.
STEP 10: That's All!
Now, just connect your clean water line to the valve on the jug and that's it! Once you open the valve, the jug should start filling and automatically stop once the float switch lifts up.
WARNING!! Relying on the float switch alone can be a water leak risk if the switch fails. I tend to close the manual valve out of habit, and the float switch is more of a safety in case I forget to close it. If you have thoughts on how to make the system safer, I'd love to hear them!
You can now enjoy unlimited water without ever having to carry water around!
18 Comments
charlessenf-gm 1 year ago
Back to my idea. Tapping into the fridge plumbing (T-fitting and valve) allows you to maintain an Everjug (tm) of "cool" cool water that has been filtered through the filter in the fridge.
Nice work BTW. Good sourcing of parts. Somewhat inspirational, as well.
One caveat before you plumb your abode for an Everjug in every room, consider what would be the result were one installed in a bedroom, say, and the valve failed whilst you were out shopping all day.
tinkrmind 1 year ago
Thanks for bringing up the water leak risk. I might not have taken it seriously enough, I'll add a warning.
However, if it only had an Ice-maker in the freezer . . . you could tap into that line and do your project in the fridge side and jet cold water faster.
stozier 1 year ago
In the picture of you holding the lid with the float assembly attached, you have a connector between the float assembly and the tank ball valve. Any advice as to a source?
Hope to see a reply soon
jon_chalk 1 year ago
PhotoJoeCA 1 year ago
Been pretty good so far.
jeanniel1 1 year ago
PhilS43 1 year ago
The tap looks like quarter turn so might have a couple of 'O' rings to seal.
Silicone gresae might help, and if there is a gland, PTFE tape usually fixes it.
Pa1963 1 year ago
ScienceDiscoverer 1 year ago
losman 1 year ago
michaelnelson 1 year ago
