K'Nex Bolt-Action Rifle
Introduction: K'Nex Bolt-Action Rifle
About: I'm a fun loving kid who likes to shoot many people in Battlefield 2. I like to make K,Nex guns...then shoot my friends in the eyes with them.
An extremely powerful bolt-action gun. Holds up to twelve blue rods in the hopper. Most ideas taken from g12345389's sniper, and I thank him for that. Follow instructions carefully, or it won't work.
Step 1: Handle
Build as shown. Note the spacers at the top of the grip. You can either do this or replace those two with two grey connectors.
Step 2: Bolt/Firing Pin
Very simple. It slides on to the back of the barrel so that a grey rod goes through the holes in the grey connectors.
Step 3: Barrel...Part One
This is the back half of the barrel where the bolt slides in. Take of the yellow connector way in the back to slide it in. Those two black pieces at the end of the picture makes up the trigger.
Step 4: Barrel...Part Two
This is the tricky part. Build exacly as seen so the bullets load in properly. The pieces in front of the barrel are optional.
Step 5: Hopper
Easy to find out. Holds twelve blue rods.
Step 6: Stand (Optional)
Make these and slide them on to the connectors right behind the trigger.
Step 7: Put It Together!
Follow pictures in order. Hopper slides on to the white connectors up front.
Step 8: Lock and Load
Put rubber bands on like this.
To load, put as many blue rods you want in the hopper. If they don't load in straight, take a large rod to push the bullet in. Pull back the bolt. If you don't hear the bullet fall in, take a rod and push it into the barrel. the trigger locks in and...
Fire!
Be the First to Share
    • Raspberry Pi Contest
    • Photography Challenge
    • Fix It Speed Challenge
    147 Comments
    jake scythe
    jake scythe
    10 years ago on Step 3
    what are the black things betwen the gray yellow conectors
    squiddy412
    squiddy412
    Reply 9 years ago on Step 3
    they're y connectors
    Abcwtfidontcare
    Abcwtfidontcare
    10 years ago on Step 8
    Turn it upside down, add a mag pusher, and a pump on the yellow connector attached to the ram and this could be pump action! :D
    rrr67
    rrr67
    11 years ago on Step 2
    could i use a black rod cuz they're stronger
    kickbottom
    kickbottom
    11 years ago on Step 3
    can somone please help me out and explain the pic PLEASE!!!
    joemarks
    joemarks
    12 years ago on Step 4
    is there anything i can use exept the tan clips cos i have about 2
    kody_dl
    kody_dl
    Reply 11 years ago on Step 4
    you could use blue connectors instead
    mettaurlover
    mettaurlover
    Reply 12 years ago on Introduction
    use BLUE clips: they're the same except without the little tab.
    SonicX 22
    SonicX 22
    11 years ago on Introduction
     even though it looks bad (no offence) i still like it!
    guns like those have good range and/or power
    koeni887
    koeni887
    12 years ago on Step 1
    does this wapen have a replaceable mag
    Lowney
    Lowney
    This isn't actually bot action. It's just a semi auto (in K'nex terms)
    hirador
    hirador
    And is it right that a grey connector is the same as a yellow one
