Introduction: KITTY LITTER FACIAL MASK
The main ingredient to expensive masks is bentonite clay. Kitty litter with no added ingredients is nothing more than bentonite clay. Here is a recipe you can make that will give you a professional mask costing pennies to make.
The reason this mask works so well is when water is added to the kitty litter it changes the molecular structure and an electrical charge is produced which draws out the toxins into the clay removing them from your body. If you do not like the idea of using kitty litter for a mask you can buy bentonite clay at most health food stores.
This mask works best on oily skin with large pores. Do not use if you have dry skin.
Step 1: WHAT YOU WILL NEED
KITTY LITTER ( sandy type is best) MAKE SURE IT IS 100% natural with NO additives
ESSENTIAL OIL your choice
COFFEE GRINDER OR HAMMER/ CLOTH ( if you have granular types)
HONEY
SMALL MIXING BOWL
MEASURING CUP
WATER
CUCUMBER
SPOON
GLASS OF DRINKING WATER
MICROWAVE
Step 2: GRIND LITTER If Using Granules
I wanted to use what I had on hand so I ground up my litter using a hammer and a cloth because I am away from home and did not have a coffee grinder. It is much easier to use the fine ground kitty litter.
Step 3: POUR LITTER INTO a SMALL BOWL
Pour about a half a cup of the finely ground litter into a bowl and add just enough water to make a thick paste. Add a drop of your essential oil to give it a more pleasant smell. Stir until you have the desired consistency.
Wash your face with hot water and cleanser to remove make up and dirt. Pat face dry.
Step 4: HEAT YOUR MIXTURE
Heat your mixture in a microwave for a couple of seconds. I am visiting my daughter so I decided to make this fun and give her a facial. Apply generously to your face using upward motions. You can cut a couple of slices of cucumbers to go over your eyes to lighten dark circles. Leave mixture on for about 20 minutes. As you can see this mixture was a little too thin. It is also courser because I had to grind my granules. My daughter liked it courser but I prefer the powdered type.
Step 5: WASH FACE
Wash off the mask using warm water. Finish off with cold water to close your pours. Pat face dry with a towel. I have found that straight honey is wonderful for the skin. We put honey on my daughters face, hands, arms, and legs and left it on for about 10 minutes. Over all her reaction was she noticed her face was softer. She said she would like to try this again to make up her mind if she liked it or not.
First Prize in the
Beauty Contest
25 Comments
6 years ago
I'm so glad to know about this because buying bentonite from the health food store is so expensive! But one very important thing not mentioned here is that you can not use metal containers, utensils, or anything metal for bentonite. The metal will effect the magnetic charge the clay carries, therefore neutralizing it's effectiveness. Also, raw honey works so much better than regular store bought honey. And, since most kitty litter is sodium bentonite, don't mix vinegar with it. I wipe my skin with raw (with the 'mother') apple cider vinegar first, then apply the facial mask after the vinegar is completely dry.
Reply 6 years ago
Why is raw honey better for your face? I'm not sure I understand how that would work since honey is honey. I'm eager to learn though.
Reply 6 years ago
Honey is pasteurized like milk. Pasteurization is a heating process that "sanitizes" it. But killing off of the bad stuff also kills off the enzymes and nutrients.
Reply 6 years ago
So raw honey isn't pasturized? I didn't know that. Very interesting!
Reply 6 years ago
Hi Becky,
Thanks so much for stopping by and sharing this information. I am featuring this comment so readers won't miss it. Have a safe and happy holiday season.
sunshiine~
6 years ago on Introduction
ds s very interesting n helpful,,wl try it with olive oil...tnx a lot !
7 years ago
Would this work on oily skin? Because I know cat litter absorbs liquids, right? Wonderful idea! Never thought of it=)
My guess is that it will! Cheap to try so go for it! I hope your day shines!
sunshiine~
can i do lemon juice or pure juice instead of expensive oils?
7 years ago
Cool I did a similar facial instead mine was for acne and was made of honey and cinnamon.
9 years ago on Introduction
It seems great. I will try it.
Thanks for commenting and do have a happy 4th.
Sunshiine
10 years ago on Introduction
great idea, but i have cleaned TOO many cat boxes to ever do this.
I hear you! LOL
11 years ago on Introduction
Isn't kitty litter bad for pregnant women, or is that a wife's tale? haha
Reply 11 years ago on Introduction
It's used cat litter that pregnant women are told to avoid (and cat poo in general) because of the risk of toxoplasmosis, caused by a parasite. http://en.wikipedia.org/wiki/Toxoplasmosis Yeah, yeah, wikipedia isn't the best source. Here's another one. http://www.mayoclinic.com/health/toxoplasmosis/DS00510
I am guessing if it is bad it is after cats have used it and changing the litter would be bad for pregnant women possibly because of the bacteria. I have not heard anything but that would be my guess.
Well......sounds good......looks cool. I have used bentonite in the process of "clogging" pipes to prevent water and gases from coming through. It came in a dust form , added water to pump it in the pipe. I do know "Fuller's Earth" is the clay used to make many brands of Cat Litter though. It is about 60 feet below earth level. The "dust" from it is very absorbent too. It will suck up an oil spill better than most things I have ever seen. If possible I suggest using the "Dust" from the granules and mix with water or lemon to a "peanut butter" texture. Just some input here, not taking away from this idea.
Your comment is most welcomed, thanks for the input.
In India they use a mixture of honey and tumeric, in fact that is a tradition for brides on their wedding day. It makes the skin glow. (no, you will not look jaundiced, the yellow washes away with the honey.) Thanks for a good idea!
