KMini AM4203 Assault Rifle
Intro: KMini AM4203 Assault Rifle
- KMini Dual Rail
- Mini Dummy M203 grenade launcher
- KMini Lock 'n' Load Barrel
- Dummy Magazine for Grip
- Firing Pin Safety
Lock 'n' Load
The Am4 uses the Lock 'n' Load barrel system, which traps the round inside the barrel. With such a short weapon, usually, the barrels are open, which means the round in the gun is likely to fall out the front of the weapon, which can be annoying in the event of a knex war, or when you are moving the weapon around. The Lock 'n' Load barrel fixes this problem, by locking the barrel at the end once the round it loaded. It is a simple and useful System. All of the KMini guns use this feature.
Firing Pin Safety
To prevent clumsy misfires, the AM4 features a firing pin safety, which while loading, will hold the firing pin back.
Slide Trigger
As the KMinis are much smaller than normal Knex weapons, they all feature slide triggers. These triggers sit underneath the barrel of the gun. Rather than pulling a trigger back towards you, you pull the trigger sidewards, to either the left or right depending on the weapon. These triggers are easy to use, and use Easy grip areas to make the gun practical.
Compact and Strong build
All of the Kminis are pocketsize, to make them easy to transport and use as few pieces as possible. Each one of the KMini guns uses less that 100 pieces guaranteed, which means there are less pieces to break and they are very quick to create, much cheaper and therefore much more practical.
No more clumsy firing pins
As the KMinis function using such simple mechanisms and are so small, all of the KMinis work extremely efficiently.
There are 4 series of KMinis:
PSeries - Shotguns
ASeries - Assault rifles and SMGs
SSeries - Sniper Rifles
HSeries - Heavy machine guns, and artillery like weapons
Other KMinis will be released soon.
STEP 1: Building the Gun - 1
Here is the piece list for this weapon:
3 Yellow Rods
3 Yellow Half Moon Connectors
2 Y Clips (1 Optional)
2 Single Grey Connectors
2 Double Orange Connectors
2 White rods
5 Blue Rods
3 Thick Silver Washers
3 Thin Blue Washers
2 Tan Clips
4 Grey "Pie" Connectors
9 Red 1/4 Connectors
1 Ball Joint Connector (Optional)
1. Create the back portion of the gun.
2. Create the front portion of the gun.
3. Connect the two together.
4. Insert the firing pin into the barrel.
STEP 2: Banding Up - 2
Use the stronger band for the firing pin.
1. Flatten the first band and put it through the firing pin hole.
2. Take the ends of the band and put them each on the yellow rods at the end of the gun.
3. Take the second band, double it up, put it on one of the prongs of the yellow connector and run it up to the socket.
STEP 3: Loading and Firing - 3
The weapon is designed to fire green rods, please post any more convinient and less expensive alternatives!
1. Lock the firing pin on the safety catch.
2. Pull the trigger back away from the barrel to feed the bullet through the muzzle of the gun.
3. Let the bullet drop into the chamber and let go of the Trigger.
4. Unclip the Firing Pin.
5. Fire the weapon!
STEP 4: Finished! Feedback and Comments - 4
Please submit feedback and ratings below, and request any improvements you feel are neccesary for the gun. Don't forget, these guns can always be improved! So if you have any improvements to show me, then post them below and I will review them, and if I think they are reasonable improvements, I will post them.
YOU MUST INCLUDE A PICTURE FOR ME TO POST THE IMPROVEMENT!!!
Thank you for creating the AM4203 KMini Assault Rifle. Please watch out for any new releases!
8 Comments
LvNo1000 11 years ago
hugamo67 12 years ago
TigerNod 14 years ago
DJ Radio 14 years ago
If a gun is designed right, it doesn't need a firing pin safety, The lock and load has been done in the form of a bullet lock, which works much better and gives the gun optimum performance.
KMiniSeriesArms 14 years ago
I had an idea about using a trigger, but it didn't turn out so well. But I take your criticism onboard. If you have any suggestions towards improvement, please post them.
~KGB~ 14 years ago
