K'Nex Crossbow
Intro: K'Nex Crossbow
This instructable shows how to build a working K'Nex crossbow. Please be smart when using this, it can be dangerous. I suggest not using sharp projectiles and not aiming at anyone. I have a few dents in my wall from early testing.
STEP 1: Key
- Build: build from scratch, unless otherwise noted.
- Attach: adding pieces to an existing thing
- Details: nothing new, just a different view
Here are all the parts and names used in this instructables.
STEP 2: Parts List
Rods
- 15 Red
- 50 Yellow
- 82 Blue
- 10 White
- 95 Green
- 2 White
- 73 Yellow
- 5 Gold
- 11 Green
- 17 Red
- 60 Orange
- 43 Dark gray
- 35 Beige
- 7 Black rod/connectors
- 23 Silver spacers
- 36 Blue spacers
- 2 Hinges
- 2 Chain links
- 13.5" Orange track
- 40" string (any string that isn't too springy, I use fishing line)
STEP 3: Starting Springs
- 16 Yellow connectors
- 12 Red rods
STEP 4: Spring (right)
- 1 White connector
- 2 Yellow connectors
- 4 Dark gray connectors
- 1 Green rod
STEP 5: Spring (left)
- 1 White connector
- 1 Green rod
STEP 6: Spring (center, Part 1)
- 1 Yellow rod
STEP 7: Spring (center, Cut Gold)
- 1 Gold connector
STEP 8: Spring (center, Part 2)
- Gold connector from last step
- 2 Red connectors
- 2 Beige clips
STEP 9: Main Body
- 47 Yellow connectors
- 3 Gold connectors
- 9 Green connectors
- 4 Red connectors
- 36 Orange connectors
- 36 Yellow rods
- 63 Blue rods
- 72 Green rods
STEP 10: Combining Layers and Spring
Temporarily remove the beige clips attached to the yellow beam on the center of the spring. This will allow you to shift the connectors snapped onto it around, making it much easier to connect the layers.
NOTE: Make sure the gold track guide layer is the center layer, connected to the gold track guide connector which you cut earlier.
STEP 11: Trigger Housing Start
- 7 Red connectors
- 9 Orange connectors
- 11 Dark gray connectors
- 4 Beige clips
- 2 Yellow rods
- 6 Blue rods
- 18 Green rods
- 2 Black rod/connectors
STEP 12: Adding Slidebars
- 3 Dark gray connectors
- 3 Red rods
- 3 Black rod/connectors
- 15 Silver spacers
- 6 Blue spacers
STEP 13: Finger Trigger & Mechanism
- 7 Orange connectors
- 12 Dark gray connectors
- 5 Beige clips
- 4 Blue rods
- 10 White rods
- 2 Hinges
STEP 14: Partially Assemble Trigger Mechanism
- 3 Blue spacers
- Rubber band(s)
Note the black connector/rods connecting to the white rods in the second picture.
STEP 15: Trigger Housing Hinge Guide
- 3 Orange connectors
- 2 Beige clips
- 1 Yellow rod
- 8 Blue spacers
STEP 16: Trigger Housing Mid Beam Support
- 2 Green connectors
- 2 Beige clips
- 1 Yellow rod
- 5 Blue rods
- 3 Green rods
- 8 Silver spacers
- 9 Blue spacers
STEP 17: Trigger Release
- 2 Orange connectors
- 6 Dark gray connectors
- 4 Beige clips
- 1 Yellow rod
- 4 Blue rods
- 2 Chain links
- 10 Blue spacers
STEP 18: Connect Trigger Housing to Main Body
- 4 Yellow connectors
- 1 Gold connector
- 4 Red connectors
STEP 19: Pins & Track
- 16 Beige clips
- 8 Yellow rods
STEP 20: String
- 40" of string (any string that isn't too springy, I use fishing line)
STEP 21: Bolts
Parts for one bolt
- 2 Purple connectors
- 2 Light gray connectors
- 4 White rods
- 4 Blue spacers
STEP 22: Done!
Again, I suggest not shooting sharp objects with this, and not ever aiming it at people.
Apart from that, have fun with your new crossbow!
13 Comments
Thor MCMXCVII 11 years ago
Storm950 14 years ago
~KGB~ 14 years ago
AlexWillisson 14 years ago
~KGB~ 14 years ago
DJ Radio 14 years ago
Also, this is only my first K'Nex weapon. I don't have much experience in designing them.
Mr. Muggle 14 years ago
