Kahoot Flooder
Intro: Kahoot Flooder
This is a fun tool if you need to annoy your teachers at school while you are playing kahoot. It visibly slows down the kahoot when you put more than around 500 bots
STEP 1: Materials
You need a pc with node js 14+ installed and a kahoot acount to test
STEP 2: Setting Up Package.json
Create a new file called package.json in your bots own directory
copy this code inside it EXACTLY except the title if you want to change that but it cant have spaces
STEP 3: Installing Libraries
once you have the package.json set up exactly like that (this step has to be done after the first 2) open a terminal and do npm install. This takes the libraries listed in package.json and installs them.
STEP 4: Starting the Code
create a new file in the directory called index.js
you can change this name but if you want it to work you have to edit the entry point in package.json
I will be going over this code later, but if you want to skip right into making the bot work, skip ahead.
STEP 5: Going Over the Code
This code basically calls the libraries for input and then picks a random word and connects to kahoot
thats it
STEP 6: Running the Code
To test the bot open a terminal and do
node index.js
and start a kahoot and follow the instructions in the terminal
2 Comments
Miles Keyser 2 years ago
griefking1000 2 years ago
