Introduction: Ant Farm
Hello, everyone! We are back with another episode of Minecraft Creations (I'm still young, so please don't be rude) and today I am going to show you how to build an ant farm! Don't worry, for they're only passive mobs, and don't bite. So let's get out there and start building!
Step 1: What You Need
To make the ant farm you will need the following:
Glass
Any fence
Passive mob eggs (Sheep, Mooshroom, etc.)
Glowstone (not shown)
Podzol (not shown)
Any block (not shown)
Vines (not shown)
Optional:
Shovel
Pickaxe (if there is stone)
Not Needed (just used to corral the animals for the screenshot):
Iron bars
Sandstone
Step 2: Flat Surface
Do one of these:
1) Find a flat surface
2) Make a flat surface
3) Build on a superflat world
Step 3: First Hole
Make a 4x4x3 (length x width x depth) hole in the ground (torches can also tell you how wide, etc.) .
Step 4: Second Hole
Dig another hole that is the same size and depth like the first one. Notice that there is a two block distance in between the holes.
Step 5: Tunnels
In between the squares that you made, make a 2x2x3 hole in the center. Please ignore the slabs, I had to keep the torches in the air.
Step 6: Repeat
Repeat steps 4-5 until you have your own pattern of tunnels. An example is shown above.
Step 7: Ants
Spawn the animals in the ant farm. Now you can see them crawling about!
Step 8: Roof
Put glass on top of the tunnels. In the center, there should be a 2x2 hole, so you can make more ants. Make another hole on each dead end (should be at least one).
Step 9: Towers
Make a tower on each dead end hole. The tower should be four blocks tall. Add a fifth layer with podzol/coarse dirt.
Step 10: Top Layer, Glass Walls
Once you have added podzol to both towers, make a podzol surface [1]. Once the surface is done, add walls of glass, 3 blocks tall [2].
Step 11: Glowstone Lanterns and Glowstone Stairs
Meanwhile, under the podzol, it is getting dark, so add some lanterns to lighten the first layer [1]. Add stairs by using glowstone in a spiral shape, inside the tower [2-4].
Step 12: Watchtower
Use any block (I used coal) and create a two-layered tower you can climb to view your ant farm. (The glowstones are supposed to be holes) [1]. Add fence around each layer [2] and glowstone on each corner of the fence [3]. Now add vines on the pole (for climbing) and you're done!
Step 13: Conclusion
Thank you so much for reading my instructable. I hoped you liked it! Ask me what I should make next in the comments below.
I will see you in the next instructable. Bye!
UPDATE (3/4/2016): Since nobody asked me what to make next, I have another project under construction! See you again soon!
3 Comments
2 years ago on Step 8
You could have used barrier blocks instead of glass; barrier is invisible and glass has white stuff all over it. But I still like it!
8 years ago
Looks interesting and cool:-)
8 years ago
I love your minecraft creations!
