Introduction: Kawaii Mini Notebook Diy
About: I am with you with wonderful room decoration ideas, do it yourself videos, back to school, practical recipes, easy handcrafting projects that you can make in a few minutes without getting bored.
Hi Friends. I made a kawaii mini notebook in this video. There are so cute. I made easy kawaii mini notebooks in this video.
Step 1: Materials:
Foam (eva) or felt, A4 paper, glue, rubber rope (for crafts), scissors, ruler, markers.
Step 2: From A4 to A5:
Cut the A4 size white paper into 2. We need half of A4, that is, an A5 sized paper.
Step 3: A5 Size
Cut the A5 size paper into 2. Set one of the papers aside. It will be needed later.
Step 4: Follow Numbers:
Fold the paper sequentially according to the numbers in the photo. Fold the dark red lines in the photos and then unfold them. 8 small boxes will be formed in 2 rows on the paper. You can see this clearly in photo number 8.
Step 5: Cut:
Leave 1 box from each of the 2 rows on the left and cut the paper right in the middle. You need to cut the part in the photo from the lines.
Step 6: Fold:
Fold the boxes in every 2 rows in a zigzag pattern.
Step 7: Glue:
Glue the top 2 sides together with glue after folding. (it looks like A and B in the photo)
Step 8: Zigzag Snake:
Open the paper after the glue has dried. It looks like a zigzag-shaped snake as seen in the photo. Turn the middle part of the paper downwards (it should be towards you)
Step 9: Cut 2:
In the same way, make another snake. (we reserved a paper for this before). Glue the zigzag snake-shaped papers together at the ends. (it looks like A and B in the photo)
Step 10: Foam:
Cut a rectangle from the foam. Glue the white paper sheets (we just made) right in the center of the foam. If the foam is large, you can cut it with scissors.
Step 11: Rubber Rope:
Glue the 2 ends of the rubber rope to the inside of the foam.
Step 12: Looks Clean:
Glue the last of the paper sheets to the foam. So the mini notebook looks clean.
Step 13: Decorating:
With markes, you can draw any patterns and shapes you want on the foam. It will look great without drawing any shape if you use glitter foam. You can draw with acrylic paints instead of markers.
Step 14: Video Step:
This is my video about this kawaii mini notebooks. You can also see all details on my video.
