Key Holder From Scrap/fire Wood
Introduction: Key Holder From Scrap/fire Wood
About: i am 14 from Ballarat Australia. i love diy and woodworking follow me on google+ https://plus.google.com/116265212847251923857
This project is a key holder made from scraps someone was giving away as firewood after an extansion to their house. It was most likely used for decking. i saw this opportunity and went through the pile of wood and took the nicest pieces. this is what i made.
Enjoy
Step 1: Choose a Piece of Wood
I went through the box of wood looking for a piece longer
than 20cm (7.8 inches) with no large areas of damage.
I found one that was 25cm long and only had some small chipping on either end but this did not matter, as I needed to cut it to length.
Step 2: Sand
This step is optional
Sand the piece of wood flat to remove any cupping in the board. This could also be done by hand or in a drum sander or thickness planer.
Step 3: Cut to Size
Cut the wood to your desired length using a saw.
I used a handsaw and a mitre box but you could easily just use a mitre saw or table saw. I cut mine to 20 cm, which will make the next step much easier if the number is devisable by 4.
Step 4: Position and Attach Cup Hooks
It is now time to insert the cup hooks.
I was adding in three hooks so I split the wood into quarters and at every line, I added a hook. This meant that there was a hook at every 5cm.
Step 5: Time to Ad Some Text
I created a stencil on paper by printing out the word keys
and using an exacto knife to cut out the letters. I glued the paper down onto the wood being sure to have it centred and painted over it.
Step 6: Remove Stencil and Finnish the Wood.
I removed the stencil by
peeling from the corner raising the paper. I then gave it 2 coats of oil and added some hanging hardware on the back.
Step 7: Complete
you now have a key holder you can show off to your friends or give as a gift
Before and After Contest 2017
Unusual Uses Challenge 2017
Home Improvement Contest 2017
Be the First to Share
    • Make it Fly Challenge
    • Backyard Contest
      Backyard Contest
    • Fruit and Veggies Speed Challenge
