Introduction: Key Rack
Key rack made from keys and pallet wood highlighting the importnce of sustainability and recycling.
Materials
Recycled pallet wood 25-30 cm
Sandpaper
20mm screws
Measuring tape/ ruler
Blowtorch
Drill
3x keys
Varnish
String (approx. 25cm)
D-loops x2
Step 1:
Take your recycled pallet wood and make sure that it is clear from any nails or debris.
Step 2:
Use a piece of sandpaper to any smooth rough edges. Watch out for splinters!
Step 3:
Measure the wood and make 3 marks evenly where the keys are going to be placed.
Step 4:
Use your drill to create 3 pilot holes in the wood. Be sure not to go right through the wood!
Step 5:
Next use the blowtorch to burn the wood to give it a more natural and rustic look.
This time the blowtorch is used to bend the keys. Use a pair of pliers to hold the key over the flame for approx. 30 seconds and simply bend the end of the key to create a hook.
Step 6:
The key should look like this with the end acting as a hook, ideal for hanging your keys!
Step 7:
Next the 20mm screws will be used to attach the keys to the wood. The hole in the top of the keys should be a perfect fit for the screws.
Step 8:
Next is the varnishing. We have used a matt varnish spray and applied a coat, leaving it for 30 minutes to dry.
Step 9:
Once dry, turn over and attach the D-loops to the back of the hanger. Ensure that the hook part of the loop is to the top so that the string can be easily attached.
Step 10:
Place the string through the D-loops and tie a knot either side. Cut off any excess string!
