Keychain 808 Spy Camera With PIR Motion Detector Controlled by Arduino Chip
Intro: Keychain 808 Spy Camera With PIR Motion Detector Controlled by Arduino Chip
This project describes how to automatically take photos with 1024x768 pixel resolution
using a miniature Model #3 808 keychain spycam with 8GB microSD card
triggered by a PIR motion detector
and steered by Arduino chip.
After issuing signals to camera buttons, Arduino chip is put into power-down mode waiting for the next interrupt to come from the PIR detector. Power consumption in power down-mode is 0.4 mA from a single LiPo cell.
Please see detailed description in the pdf file.
Example video from snapshots:
http://youtu.be/qPLUeetCsy8
18 Comments
CédricV2 8 years ago
Hi everyone,
One could also use https://kerberos.io/, it runs on the Raspberry Pi and it's also open source.
zacker 9 years ago
Akin Yildiz 9 years ago
or you can use this to directly connect to your 11.7V battery; http://www.ebay.com/itm/3A-DC-DC-Converter-Adjusta...
just adjust the output to 3.7V and you should be good to go !!
just negative and positive are all you need, check out my post on this topic; https://www.instructables.com/id/usb-power-source-h...
DE8MSH 11 years ago
http://www.youtube.com/watch?v=9YYpdw7l8Z0&list=UU5P5q0e04M5xDLwnyNmJT3g&index=1
Setup:
Arduino
Camera
Servo
Just for fun and prrof of concept ;)
i need your help, please go here and read my comment; https://www.instructables.com/id/Arduino-keychain-c...
srikanta44 9 years ago
i brought a key spy cam... but its not working.... i checked that if m connecting it to my laptop for charging the orange light is glowing..but its not getting on..shall i ve to change the battery???? which battery i should use sir??
Jsmxbox 12 years ago
jwkooi 12 years ago
I am busy with the 808 time lapse setup.
I used a zenerdiode 2.2V and a 10K resistor connected to the output of the arduino. (twice) to get the 3.3V. (ok it is 2.8V)
Switching the 808 on and off works. But I can't get the mode button working. I noticed in your schematic that you use a different circuit for the mode button with a potmeter and a diode. Why is that?
Or was it just trial-and-error?
janisalnis 12 years ago
For taking a picture, it did not work for me directly from Arduino like you tell. Then I measured the voltage on the picture taking button, when it was pressed and it was smaller, ca 2V. I do not know why. So I used a potentiometer to trim Arduino output to the necessary voltage, And then it worked fine.
jwkooi 12 years ago
To be continued.
p.s. I am pretty sure I have a 808 type14.
jwkooi 12 years ago
JW
jwkooi 12 years ago
First thing I need to do is open the camera case and solder the wires. I do have some Arduino's and finisihed a couple of project already including a timelapse systeem which my digital camera triggered with servo's.
I am going to check the schematic of the 808 to see where the buttons are connected. Maybe I find a better alternative than your potmeter, diode construction. Although, your way seems to be simple and effective as wel.An low on power consumtion,
Jan Willem (the Netherlands)
https://www.instructables.com/answers/Can-somebody-name-all-the-components-I-would-need-/#DISCUSS
jwkooi 12 years ago
jpg quality is worse than the video quality.
Jpg is probaly 640 x 480. It is a pitty.
